Old 18th October 2010, 06:31 AM
Nick1
Guest
Posts: n/a
had both split c.v boots replaced last week oil every were would this affect the abs sensors ????
Old 18th October 2010, 07:52 AM
May do if they got covered in it.
Take off the wheels, remobe the disks and they are on the front of the hubs. I'll post a picture tonight.
Old 18th October 2010, 10:54 AM
Nick1
Guest
Posts: n/a
thanks for your help conan
Old 18th October 2010, 03:44 PM
Nick1
Guest
Posts: n/a
did a scan today and it showed this
Monday, 18 October 2010, 09:23:12.
VCDS-Lite Version: Release 1.0
Control Module Part Number: 4D0 907 389 E
Component and/or Version: ABS/ESP allrad D57
Software Coding: 08397
Work Shop Code: WSC 02313
1 Fault Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Old 18th October 2010, 04:20 PM
There should be a corresponding fault on the transmission with that code. If not it could be the speed sensors just need cleaning.
This link has a bit more info.
Old 18th October 2010, 06:41 PM
Picture as promised. Note you may have bolt in sensors not push fit as per the picture. Just remove reinsert with some coppaslip and retest.
Old 18th October 2010, 07:49 PM
Nick1
Guest
Posts: n/a
transmission scan is coming back clean,would this be pointing me in the direction of the abs sensors
Old 18th October 2010, 07:59 PM
It's not a difficult job and will take them out of the equation.
Old 18th October 2010, 09:15 PM
Nick1
Guest
Posts: n/a
cheers conan will give it ago tomorrow ,will let you no how it goes
Old 10th May 2012, 06:48 PM
thebluewhale's Avatar
Default Holy thread resurrection Batman :-)
Nick are you still around?
Did cleaning the ABS sensors solve the problem or was it something else.
I am getting similar symptoms to you but don't have the ABS light on or any fault codes.
The vibration only happens when the car is stationary and in gear (drive). If I put it in neutral it goes away. When I pull away it goes away.
I'm thinking it's gearbox/engine mount maybe?
Any ideas anyone?
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had
THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again
