Old 10th May 2012, 06:55 PM
47p2's Avatar
47p2 47p2 is offline
Originally Posted by thebluewhale View Post
The vibration only happens when the car is stationary and in gear (drive). If I put it in neutral it goes away. When I pull away it goes away.
Sounds like it could be a gearbox related problem...Possibly torque convertor
Nite Blue 3.0L SE Quattro
Old 10th May 2012, 07:01 PM
Iyole Iyole is offline
No harm in cleaning the ABS Sensors to eliminate as a possible cause....
Easy DIY..... http://www.audipages.com/Tech_Articl...eshooting.html
But I somehow don't think that is the issue by the Symptoms described...
There is also a Campaign on the box lever bracket.... mine was replaced 3
months ago..... Worth checking with your local Agent
2002 S8 D2 F/L
Old 10th May 2012, 07:12 PM
thebluewhale's Avatar
I'll start with the ABS and see if anything changes.
I hope you're wrong on that one.
It's not a big vibration but a noticable one which has appeared over the last few weeks. Very annoying.
Thanks guys
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had
THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again
Old 10th May 2012, 07:46 PM
Perhaps a long shot, but relaively easy to check and fix - power steering pump filter? When mine went it had similar symptoms (unfortunately the whole pump was duff, but many folk get away with an oil change and filter clean). Mine made a noise and vibration, worst in reverse, and I thought it was the gearbox. Slip the filter out and see if it's blocked as a first attempt.
Old 10th May 2012, 08:52 PM
B@fink B@fink is offline
where is this filter? is it just in the bottle neck? figure I can have a look if it's a 2 minute job, mine makes no undue squeeks or vibes but prevention is better than cure
Old 10th May 2012, 09:18 PM
Yep... Take the cap off, and then the filter pulls out. Clean filter should be shiny, mine was pretty black on my PF and it made a scary noise when you had a good bit of right lock. Cleaned the filter and it sorted itself out.
