wondered if you could point me in the direction of where you got the firmware upgrade from Manny please?
cheers
Audi S8 2015, Daytona Grey |
Brian, the filename is AUDIFW2003.zip
Download here, http://www.lumpistefan.de/Audi/AUDIFW2003.zip Then basically extract the zip file to a folder. Then using Nero, Roxio or simillar create a standard data ISO CD (Not UDF format) and drag / drop the contents of the folder onto the CD. Burn at a slow speed (I used 4x) and make sure the session is closed. Restart the RNS-D holding down the flag and navigation buttons as you press power. Select Eject CDRom, and remove the navigation CD. Insert your FW disk, and at the bottom it should pop up next to CD version as 2003. below that are two options, select the top one, not the TMC one. System will check CD, restart, and update the headunit, System will restart again, and update the graphics software, System will restart again and tell you that the update was successful. Remove now ejected firmware CD, and put your nav disk back in. Press the right knob in to accept, don't do what I did and press return as prompted.
thanks for that, might give it a try if it improves the sound quality
cheers ![]()
The hex socket no 4. to undo the bolts on the instrument cluster and then it will pull forward....when you do put a towel over the top plastic part of the steering wheel as the instrument cluster might scratch it as you are fiddling to get the plugs off.
If the plugs havent been off will be some zip ties back there...patience and you will succeed. The two can wires you want to tap into are on the green plug. pin 21 for canbus low pin 22 for canbus high Good luck you are almost there!!!!!
01 Audi a8 fl sport - Grey, Bose, Glass Sunroof, S8 grill/mirror covers/wheels, Aftermarket Exhaust, very quick and lots of fun!!!!!....well I gave it one final push on the pedal to hear that v8 growl and then it was off to a new home..... 99 Audi a8 fl - Silver, Black alcantara seat/ S8 grill/side mirror, MFSW, Solar Sunroof, 17" Monoblocks (for that extra cushion of air), Rnsc, Bose.....great motorway cruiser....now gone to a new home 02 Final Edition S8 - Avus Silver, Extended Leather Pack III, Front & Rear Heated Seats, Servo, Blinds, Rear Seat Entairtainment with Playstation, Bose, Bi Xenons.....now gone to a new home 97 PF A8 4.2 quattro sport - Cashmere Grey, Servo, RNS E, Blinds, Bose, 20 Final Edition Alloys, LPG....sold sadly and will be missed 03 S4 V8 Saloon - Misano red, Manual, Milltek, Bose, Xenons, RNS E - Sold as of Feb 2012 |
Yep, almost there.
However, today I drove around town with the GPS aerial sitting on the dash. The RNS-D is seeing 8 satellites, so no problem there, however the map position completely wrong. The arrow is behind by a good 300 yards or more, and slightly to one side. Can you calibrate your position on the map using the crosshairs like you can on the VW MFD/MFD2?. I hope its not a bad GPS aerial, don't think it is as the compass display works well. Tomorrow, I am off to Hertfordshire from Dorset to finish the install and put the car back together. I'll put some pictures up of the install when finished of course, but I am sure you have all seen an A8 with RNS-D a hundred times before.
What happens when you park up does it eventually get the position right?
The satnav uses the inbuilt compass to work out which direct the car is heading and the speed signal from the car, the position is then corrected by the gps every minute or so. |
Isn't it 0.05 miles?
I did this just the other day, using the procedure above. ![]()
You're right. Had to go out for something and checked. Don't know where I got the 0.1m max resolution from.
