Old 21st February 2013, 04:33 PM
SilverS8 SilverS8 is offline
Remember jo adjust the Control arms when fittting or they will be worn out pretty fast since lowering will give them new "permanent" positions
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 21st February 2013, 04:53 PM
stig1983 stig1983 is offline
Thanks, been told ill also need to get the car 4 wheel aligned but to only go to someone who is good at it and knows what there doing. Can anybody recommend anywhere to get this done. Thanks
Old 21st February 2013, 05:49 PM
Although there may be others on this forum who may disagree, I alway use my local KwikFit for this (Altrincham) who are excellent. They use a Hunter alignment rig on my s8 every 6 months or so (I go over lots of speed bumps and potholes - slowly of course ). Other KF branches may or may not be so good...
Old 22nd February 2013, 06:54 AM
RanjS8 RanjS8 is offline
Default Alignment
Anyone with a hunter machine should be good....also check on alignmycar.com.....be warned can still be hit n miss....1 place I went to were excellent but it closed down....the second place had the machine but didn't do camber adjustments....so confirm whether or not they do that first and the relative cost.
You should only need to realign the front though if u are only touch the front suspension
Old 22nd February 2013, 11:33 AM
Curtis's Avatar
Curtis Curtis is offline
how would you adjust the control arms? and does this only apply to lowering.
Old 22nd February 2013, 01:19 PM
He means loosen the bolts and re-tighten with full weight on suspension so that bushes are locked in stress free position. Other wise they will get twisted too much and can de-laminate or wear out quickly.
Old 22nd February 2013, 03:55 PM
Default Changing to coil overs
Just wanted to add...if you have done suspension work before then this shouldnt be too bad....the only thing to really have to watch out for is the pinch bolts holding the upper arms in place. If this hasnt been touched before then be prepared for a fight....it really is a bugger when it seizes in place. With that in mind I would loosen the hub bolt that holds the outer cv joint in place with the hub. This way if by off chance you have to take the hub out for any reason then at least you dont have to get the car back on the ground to loosen it.
Also have a decent set of spring compressors for when you seperate the shock absorber from the upper subframe.
However, if this is your first time at any suspension work I would pay a garage to do it and just not go out for a weekend or two....sitting inside in the warm watching tv will be far more satisfying than doing this as a novice.
Ranj
Old 22nd February 2013, 04:36 PM
Ranj
thats my kind of car maintenance
