Currently based in Stockport and need someone to fit my new KW coilovers to the S8, cash and pints would be given in return for the job. I could help with fitting but have no idea what im doing on my own.
Ideally dont want to be paying garage prices so looking for someone who is willing to do as a foreigner. Thanks in advance Adam
Remember jo adjust the Control arms when fittting or they will be worn out pretty fast since lowering will give them new "permanent" positions
2003 Daytona Grey RS6 2000 Silver S8 2005 A6 1.8TQ Premium 1993 Audi S4 2.2 TQ MTM 330 (my first love!) |
Thanks, been told ill also need to get the car 4 wheel aligned but to only go to someone who is good at it and knows what there doing. Can anybody recommend anywhere to get this done. Thanks
Anyone with a hunter machine should be good....also check on alignmycar.com.....be warned can still be hit n miss....1 place I went to were excellent but it closed down....the second place had the machine but didn't do camber adjustments....so confirm whether or not they do that first and the relative cost.
You should only need to realign the front though if u are only touch the front suspension
01 Audi a8 fl sport - Grey, Bose, Glass Sunroof, S8 grill/mirror covers/wheels, Aftermarket Exhaust, very quick and lots of fun!!!!!....well I gave it one final push on the pedal to hear that v8 growl and then it was off to a new home..... 99 Audi a8 fl - Silver, Black alcantara seat/ S8 grill/side mirror, MFSW, Solar Sunroof, 17" Monoblocks (for that extra cushion of air), Rnsc, Bose.....great motorway cruiser....now gone to a new home 02 Final Edition S8 - Avus Silver, Extended Leather Pack III, Front & Rear Heated Seats, Servo, Blinds, Rear Seat Entairtainment with Playstation, Bose, Bi Xenons.....now gone to a new home 97 PF A8 4.2 quattro sport - Cashmere Grey, Servo, RNS E, Blinds, Bose, 20 Final Edition Alloys, LPG....sold sadly and will be missed 03 S4 V8 Saloon - Misano red, Manual, Milltek, Bose, Xenons, RNS E - Sold as of Feb 2012 |
how would you adjust the control arms? and does this only apply to lowering.
He means loosen the bolts and re-tighten with full weight on suspension so that bushes are locked in stress free position. Other wise they will get twisted too much and can de-laminate or wear out quickly.
Just wanted to add...if you have done suspension work before then this shouldnt be too bad....the only thing to really have to watch out for is the pinch bolts holding the upper arms in place. If this hasnt been touched before then be prepared for a fight....it really is a bugger when it seizes in place. With that in mind I would loosen the hub bolt that holds the outer cv joint in place with the hub. This way if by off chance you have to take the hub out for any reason then at least you dont have to get the car back on the ground to loosen it.
Also have a decent set of spring compressors for when you seperate the shock absorber from the upper subframe. However, if this is your first time at any suspension work I would pay a garage to do it and just not go out for a weekend or two....sitting inside in the warm watching tv will be far more satisfying than doing this as a novice. Ranj
Audi S8 2015, Daytona Grey |
