Old 21st October 2013, 02:10 PM
notorious notorious is online now
Default D2 FL MOD: Fog light buttons near driver's seat
OK, I'm doing a number of things with my centre console,
i.e. retrofitting radio controlled clock, tidying up wiring
and experimenting with RNS-E 2010+, AMI, can gateways etc.
So I removed wood fascia from centre console and remembered that I wanted to move those fog light buttons closer to driver's position.
Sometimes i want to flash someone with fog lights, but I just find them too far to reach in RHD car. Well, I now have all 3 buttons with LEDs
on one side, and all other less important stuff on another side. I needed to extend two fog lights sub-looms (5 wires each) to reach new position.
P.S. Yes, I know I'm crazy
Old 21st October 2013, 02:58 PM
Youre crazy!!
Surely you could have come up with some button or other on the steering wheel that fires a laser at the button where it was in the first place!
Old 22nd October 2013, 12:14 AM
I think that's a neat idea, especially since I don't have the rear blinds and I'm not likely to be pressing the ESP button. It might be something I might tackle, but what exactly is involved in the need 'to extend two fog lights sub-looms' properly?
Old 22nd October 2013, 07:02 AM
I like this too and also find that the fog light swithces are too far away for convenient use. But if the wiring needs to be extended, I'll give it a miss.
Old 22nd October 2013, 07:05 AM
You need to remove just the faceplate. Then on my car I needed to add a bit of length to wiring loom so that two fog light looms reach new button position.
There are 5 wires in each loom. Basically cut the loom in the middle and solder in a about 15-20cm of new wire so that the loom becomes longer. Then wrap new extended loom with Certoplast and it will look stock and untouched.
Old 23rd October 2013, 07:13 AM
I'm totallu useless with a soldering iron, so I'll put this mod to the bottom of my list
Old 23rd October 2013, 11:03 AM
If you go to Reading area Jim make sure you visit me. I'll solder those wires for you and will teach you to use soldering iron too -- this is very easy if you use rosin core solder. For free of course.
Old 23rd October 2013, 11:43 AM
Better still, you could bring your soldering iron up the the Annual Meet in Scotland next year!
Old 23rd October 2013, 11:50 AM
Who provides 220v power?
Old 23rd October 2013, 11:57 AM
You could stop off at my place on the way up!
