Hi Guys,
Never had an issue with my old 2000 FL S8 and the gearbox up to 235K. Just picked up the new one 98 PF S8 and it drove from London fine. Up to Leeds and Back and then Monday on the 12 miles to work I hit the A1 and it reved up high and no power. PNRD4321 on the dash and then power came back but it didn't seem to change gear. Got to work an put on vagcom 17117 - Gear 3 Incorrect Ratio P0733 Cleared this off and things worked ok. Driving home and PRND4321 came up just after starting Cleared the fault again and I could select select things on the dash and vagcom, but the gearbox didn't seem to do much. Tiptronic showed 5 not 1. I could go back and forwards, though pick-up was slow until moving forwards. Seemed like the car can go 0-??? in one gear! Drove to the supermarket. Parked up. Did stuff. Got back in and no error. Drove home fine. Yesterday morning it was fine for the first few miles and then again high rev. PRND4321 and similar problems. Clear the code and this time it seems Tiptronic shows 4. The revs are a bit higher at motorway speed, though take off is still very slow until moving. Vagcom showed 17114 - Incorrect Gear Ratio P0730 17145 - Shift Solenoid 3 (N90) : Open or Short to Ground P0761 Again I cleared them off. Left it a while. But now i get PRND4321 with a bit of a thump when i select D or R and 17145 keeps returning. Any ideas where or what Shift Solenoid 3 is ??? BTW I do still have the old S8 at the moment for parts etc! Lee |
If you mean that all gears light up on the dash, I would suggest the F125 switch might be the culprit (although the scan isn't throwing that error). Not familiar enough with the other codes, but others will be.
I've heard of the F125 switch. In playing with what was doing what I believe that the lights and certainly the mirror was acting as though reverse was selected.
And yeah all the gears on the dash as a bar or [PRND432] |
Hi There,
Been doing a bit of net research into this gearbox, solenoids and stuff and gonna put down a bit of a link dumping ground, so A I don't loose them and B it may be useful to someone else doing research into this box ZF 5HP24A - It seems to also be used in quite a few cars, as such rebuild / diagnostic info on the same box on a BMW / Landy etc is still pertinent and useful while not always being 100% correct, but.... The gearbox assembly seems to consist of two parts. The actual mechanical gears and the Valve body which is the brain / controller. The valve body sits on the bottom of the gearbox and is accessible through the gearbox oil pan with the gearbox still in situ. Diagnostic PDF - & overview on how things work http://virtusplatform.com/sam/BMW/e3...P24%20diag.pdf ZF Valve body maintenance "overhaul" http://www.bimmerboard.com/forums/posts/527361 Gearbox Rebuilds BMW http://forums.bimmerforums.com/forum...e-Walk-through Audi S8!!! http://www.motorgeek.com/viewtopic.p...46685&start=25 Landrover based but lots of info/specs http://forum.landrovernet.com/showth...5HP24-teardown And he rebuilds for a hoby http://www.rangerovers.net/forum/6-r...d.html#p298057 Solenoid positions / Names http://i260.photobucket.com/albums/i...t2008/EDS4.jpg Solenoid position / Names (official) - Also links to images of parts http://www.tsgparts.net/index.php?p=...location_5hp24 Solenoid Positions / Diagnostic info http://www.rangerovers.net/forum/6-r...l-problem.html Solenoid wiring harness http://bimmerboard.com/forums/posts/1091413 Solenoid Replacement / Swapping http://www.rangerovers.net/forum/6-r...tml#post246833 Testing a solenoid http://www.xoutpost.com/bmw-sav-foru...rror-code.html Removing the valve body - Youtube video on bench http://www.youtube.com/watch?v=rJw7RWGl0Qw Removing the valve body instructions with pics http://www.rangerovers.net/forum/6-r...tml#post247261 Overhauling the valve body & differences between UPDATED valves http://www.xoutpost.com/bmw-sav-foru...-question.html ZF rebuild manual details http://www.audiforums.com/forum/audi...al-pdf-153014/ http://forums.audiworld.com/showthre...1759363&page=5 ---- After having a think and a read and having a spare car, while the fault may be with soilnoid three, debris in the vavle body locking it out or similar. I am tempted to do a full valve body swap as it looks fairly simple. Lee |
Sounds like you may have an open circuit on solenoid 3 (i.e. it’s disconnected). Solenoid 3’s only function in life is to pressurise the opposite face of the reverse gear valve (RG-V) spool - thereby preventing engagement of the C & F clutches - in the event of the gear lever being moved into reverse while the vehicle is travelling forward at speed. Consequently it may never actually be required throughout the whole lifetime of the vehicle (unless the driver has a habit of doing this!)
![]() However, it is also activated in Neutral, which is presumably why it is being flagged by your controller. The easiest way to test it (without having to take the sump off) is to check the resistance at the 16-pin connector. ![]() If you measure between pins 4 & 16 you should get a reading of between 26 and 30 Ohms. I have loads of (used) spares if you need one. Phil |
Hi Phil,
Given your name, you appear to be the gent up in Lancashire that rebuilds these for a hobby. I recognise you from one of the Landy forums and i've read numerous of your posts. Very glad to have you here. Doubly so given my current niggles. I actually have 2 S8's one FL and one PF both with the same gearbox (fbg vs ecx but both 5HP's). The facelift one has a dead engine due to timing and throwing pistons into valves (sigh) so I got the second which has developed this gearbox fault. We did an oil flush and it was not too bad, though the magnets had silver particles. I was looking at Swapping the valve bodies, but testing sounds good. However I'm a little confused.....The Code is 17145 - Shift Solenoid 3 (N90) : Open or Short to Ground P0761 Also known as P0761 - Shift Solenoid C I was thinking from http://i260.photobucket.com/albums/i...t2008/EDS4.jpg That C was EDS5 ??? However you circle MV3 in red on one drawing and say SV3 on your pin out??? Lee |
Has mention of Shift Solenoid 3 on Page 17 as MV3 which tallys with what you say. Page 11 however says measure between pins 4 and 12 for 30-34 ohms!!! What's the difference between 12 & 16 and if someone says 4 ohms ![]() |
Sorry about the confusion regarding the correct designation for the shift solenoids. ZF refer to the shift solenoids as MV1, MV2, MV3 as the German word is ‘Magnetventil’ However, English documents (such as the example below from the Range Rover workshop manual) often ‘translate’ this to SV1, SV2 & SV3. ![]() I produced the images in my previous post months, possibly years, apart so I apologise for not being consistent! The photo you attached is taken out of context. I was answering a query regarding the torque converter lock-up clutch pressure regulator solenoid (black cap) and was advising the OP that they could swap it with any of the other three black cap pressure regulator solenoids as they were all identical. I labelled these as A, B & C on the photo just to help him identify them. The P0761 code is definitely for the MV3 brown cap solenoid i.e. the one on the end at the opposite side of the valve block to the ‘green cap’ main pressure regulator solenoid Phil |
Pin 12 is the power supply for EPRS2, EPRS3 and EPRS5 and pin 16 powers the remaining five solenoids. The ATSG manual has got it wrong. They also have all the connectors identified back to front : ![]() I wrote to them to advise them of this fact and they subsequently corrected it : ![]() Don’t worry about the 4 Ohms, you’re trying to test for an open circuit, but the correct figure is 26 to 30.4 Ohms at 20 deg.C. You’ll have to decide who to believe. Phil |
Hey Phil,
Talk about an authority when you are correcting the trade! ![]() I didn't doubt your advice, I just come from a background of research and double checking and like to get my head arround what is going on! Since i've got the spare dead car, I'm going to pull the valve body out of that one to work out what is what. It'll also give me spare parts etc. I don't know if it is wise just to swap the bodies then play with the problematic one or fix the problematic one. There is about a hundered thousand less miles on the problematic one and I know there wasn't much (if any) maintinance on the working one, though its an 02 model vs 98 so I don't know if there were any updates etc - I see that there is a Valve mod that ZF do if refurbing! Thanks for all the help, Lee |
