Old 21st January 2014, 08:22 AM
jonk jonk is offline
Good luck for the repair... Let me know how you get on. Just lift that is sometimes available or not at the mo, so perhaps the compressor is weak. For £25 I may just buy the kit and suggest the guys fit it when it goes in for the parking sensor replacement next week. Mine is 03 so an early one, lowing miles but 10 years old may need the piston rings doing.
Old 21st January 2014, 12:56 PM
mannyo mannyo is offline
Spoke to the mechanic earlier, he has fitted the kit and the suspension is back to full working order. The car now raises and lowers correctly, I'll test it myself when they deliver the car back.
He is bringing the old parts back to show me how bad it was, apparently air was escaping around the compressor piston because of damage to the old part and that is why the pressure was low. I'll post a picture of the old part when I get it back later.
Manny
Past
Old 21st January 2014, 05:22 PM
Great! I think this could be my issue too. Did a big drive today and on starting the green light was on and went out after 10 secs or so but no lift. Then after 20 mins of driving, all functions there.
I'll get the eBay kit and suggest they fit as a precaution next week. If you don't mind me asking, how much/how long was the labour for this job?
Many thanks for all your helpful feedback.
Old 21st January 2014, 05:47 PM
Here are the pictures of the old compressor part. You can see the damage, it should be smooth all the way round and mine had some nicks from the outside and quiet bad scoring. Air was escaping round the edge of the part as a result of the damage.
I was charged 3 hours labour, Rick had to spend sometime cleaning up the piston cylinder as it was in quiet a state inside. Suspension is now working great which is a relief until something else breaks.
This is what I purchased, this is the original one. As you can see Andy has sold loads of them, each is handcrafted and tested before being posted.
http://www.ebay.co.uk/itm/161120430069
ID:	7193   Click image for larger version
ID:	7194   Click image for larger version
Manny
Past
Old 28th January 2014, 12:22 PM
A8 Doc A8 Doc is offline
Ah just ordered this myself!!
Old 28th January 2014, 04:47 PM
Mine getting fitted tomorrow. Fingers crossed!
Old 28th January 2014, 05:15 PM
Mines been fine for 300 miles, until today. I have air escaping from the compressor area, as the compressor starts and stops I can here PSSHHHHT a bit like when you remove a tyre pump from a valve.
I think it only does this as the compressor starts and stops although not sure, at first I thought it may have been a HGV behind me but it did it again on the way home from work.
Could be air escaping from the output air line, or something else. Everything is still working, no fault codes. I'll give the mechanic a call tomorrow I guess.
Manny
Past
