Old 28th January 2014, 12:22 PM
A8 Doc A8 Doc is offline
Ah just ordered this myself!!
Old 28th January 2014, 04:47 PM
jonk jonk is offline
Mine getting fitted tomorrow. Fingers crossed!
Old 28th January 2014, 05:15 PM
Mines been fine for 300 miles, until today. I have air escaping from the compressor area, as the compressor starts and stops I can here PSSHHHHT a bit like when you remove a tyre pump from a valve.
I think it only does this as the compressor starts and stops although not sure, at first I thought it may have been a HGV behind me but it did it again on the way home from work.
Could be air escaping from the output air line, or something else. Everything is still working, no fault codes. I'll give the mechanic a call tomorrow I guess.
Old 28th January 2014, 08:14 PM
Probably just an airlock somewhere? The compressor might auto bleed?
Old 29th January 2014, 12:38 PM
The mechanic is popping by my workplace on his way to work tomorrow to have a listen and take the car if he thinks something is wrong. I hope the sound can be replicated on demand.
Old 29th January 2014, 05:44 PM
To confirm, I can replicate it on demand, it appears to be as the compressor shuts off. If I sit in the car and select Lift, so the car uses the air in the tank, then select Dynamic so the car dumps all the air from the struts. Finally select Lift again, so the compressor must run to get pressure back. After the car has raised and the pressure tank is full, the compressor cuts out but just as it stops there is a psssht sound lasting just a fraction of a second. Does it every time, so I can show him tomorrow morning.
The sound maybe normal, but I can't say I have noticed it before.
Old 30th January 2014, 06:48 AM
He has been, and has taken the car back to the workshop. He is happy that something is not right, so will once again gain access to the compressor. Compressor is working fine, but air is escaping from the compressor area when its running.
