Old 11th August 2014, 08:31 PM
jools_s8 jools_s8 is offline
Did the rear discs and pads a few months ago using the the car jack (but i I got a heavy duty jack to replace the standard one which collapsed when under load last year). I am not too sure whether the jack dimensions are the same but it is a struggle to get axle stands in under the jacking pads whilst using the jack on the side supports intended for the jack. I have two pairs of stands and one is slightly shorter than the other so, with a bit a squeeze, managed to place the shorter ones in the right place.
Thanks for the reply. I could not get enough of the stand on the sill without risking damage or worse the car coming off the jack.
