Old 20th October 2014, 07:38 AM
I don't have part numbers I'm afraid, but I think they just push over the existing pedal once the rubber is removed (IIRC, you might have to trim the inside of one of them).
If you or anyone else wants a footrest, drop a PM to Steve (Trophy885)
Old 20th October 2014, 09:06 AM
I'll have a closer look at the weekend to see if I can find part numbers and double check on how they're attached
Old 20th October 2014, 09:41 AM
Part numbers are here with a small writeup:
http://www.tyresmoke.net/forum/topic...-pedals/page-2
1. Audi TT accelerator pedal: 8N1 721 647 B (about 11 UK pounds)
2. Phaeton brake pedal: 3D2 723 173 A (about 28 UK Pounds)
Old 20th October 2014, 09:43 AM
Jim, what part number is used as raw material for this footrest mod?
Can we expect a writeup?
Old 20th October 2014, 09:54 AM
Yes, I'll pull all the photos together for a write up soon.
But there's no part number - Steve made this from scratch
Old 20th October 2014, 12:50 PM
Thanks. That will make things so much easier... and my sort of price
Old 9th September 2017, 01:52 PM
Default Wrong size Accelerator Pedal
I have just ordered and received a TT accelerator pedal using the part number 8N2 721647B as a previous attempt using 8N1 721647B had got me an incorrect sized pedal cover. I appreciate that 8N1 and 8N2 are for LHD and RHD cars respectively and that theres a small difference in length (LHD 105mm v RHD 98mm but this 8N2 pedal cover is ALSO wrong as its way too narrow. Can anyone advise what I am getting wrong here?
(photo shows 8N2 721647B alongside standard rubber cover.)
Old 9th September 2017, 04:21 PM
no idea as to why 8N2 was ordered.
Even though 8N1 is more narrow if it'll fit the base metal pedal then what's the problem?
Old 9th September 2017, 04:56 PM
tintin tintin is online now
I have a similar set - £39 for the pair.
Name:	Alu pedal set.jpg
Old 9th September 2017, 06:10 PM
I ordered 8N2 because, as i thought i explained above, a previous order of 8N1 had given me a too narrow shaped pedal cover. And the problem with the 8N2 cover is the same in that the width of the base metal pedal is approx 40mm and the 8N2 is approx 30mm. If the only difference between 8n1 and 8N2 is supposed to be the length then why didnt either fit my metal pedal?
For TinTin,
I may well take you up on that.
