Old 3rd December 2014, 12:46 PM
madcjd madcjd is offline
Default Tpms
Re the tyre pressure monitoring...............if VCDS is suggesting that batteries are on their way out............are they replaceable or do you need to purchase a whole new pressure sensor?
Has anyone any experience with this?
Thanks
Previous cars
A8 D4 4.2tdi lwb (2011)
T5 Caravelle exec 2.5 (2006)
A8 D3 4.2 quattro (2003)
A6 4.2 quattro avant (1999)
A6 2.8 quattro (1998)
Audi Coupe 2.6E (1993)
Carlton 3.0 GSI
Old 3rd December 2014, 06:01 PM
Yes I have had the displeasure of replacing all four sensors at the cost of nearly 500 quid plus the cost of having the tyres removed to replace them.
But I was having the wheels refurbed with new tyres fitted at same time do made more sense.
I would leave them till you have reason to have tyres taken off.
In the mean time if you have tpms failure in the did, using vcds code the system to be off and code out the option on the mmi system if you don't want it in the menu, then clear faults.
Old 6th December 2014, 07:55 AM
Cheers Del.
I was hoping someone might have said 'yes' you can replace the batteries.
£500 is a lot of cash and I think I can live without having my tyre pressures on display....although it is a 'nice to have'.
Chris
Previous cars
Carlton 3.0 GSI
Old 6th December 2014, 07:59 AM
I've always thought that tyre pressure monitoring is one electronic aid too many - too much (repair) cost, and not enough benefit, or maybe I'm just being a Scot again!
Old 6th December 2014, 09:58 AM
steamship steamship is online now
madcjd, a cheaper option to renewing the current ones might be to fit a non-OEM kit. Once such option was discussed in the following thread by moltuae:
http://forum.a8parts.co.uk/showpost....39&postcount=4
I know it seems pointless fitting another system, but considering the price differential, it could be something to consider if you really need it.
Old 6th December 2014, 10:08 AM
And, just to add: The batteries on those after-market sensors ARE replaceable .... all without removing any tyres.
Old 6th December 2014, 10:25 AM
richardracer richardracer is offline
Default Tpms replacement
Have a look at tyre pal.co.uk. £99 with discount code CH1214. Replaces valve caps, monitor fits perfectly in the ashtray, no wires required. Added benefit, can be swapped to winter wheels easily. No issues with wheel balance, protrudes around 10mm from my standard wheels. For £25 you can also have one for the spare wheel.
Richard
2006 Audi S8 V10 Now Sold. Akoya Silver with black/grey leather, standard 20" wheels, hybrid TV, Bang & Olufssen audio, Heated seats front and rear, Dension ipod integration, DAB radio, keyless entry, rear electric blind, bluetooth connection to Apple iphone6S. Started at 60,000 miles end April 12. Now 171,500 miles as at Oct 2017. Now sold to fellow forum member.
Old 6th December 2014, 01:30 PM
Thanks.
I think I've decided to just be without TP indication. It's only a ' nice to have' and as one other gent pointed out - a step too far.
Besides, I've got my eye on some nice 20" wheels and would be without the indication anyway (unless I faffed around having tyres removed twice and putting the sensors on new wheels.......when I get them).
Previous cars
Carlton 3.0 GSI
Old 6th December 2014, 01:35 PM
Richard
Thanks Richard that's not a bad system for the money especially with the discount code
Old 12th December 2014, 05:41 PM
You know what needs to be done is for someone who makes the valve cap sensors to make it compatible with the Audi so it can still report in the dis.
