Old 30th December 2014, 06:55 PM
mark_le_b mark_le_b is offline
Question Help! S8 Scary Engine Noise...Worried
Hi all
My 2002 S8 has developed a worrying engine noise.....any idea what it is?
Not even sure if its safe to drive to the indi!
Sounds like top left of engine as you look as you stand in front of car
Link below can be cut and pasted into browser to listen
Thanks
http://youtu.be/rhE6tbx_cw8
Old 30th December 2014, 08:06 PM
I presume that the revs were steady at tickover throughout that clip? Does it change with revs?
If I remember you dont have VCDS?
Old 30th December 2014, 08:27 PM
Hard to say from video but it could be secondary air injection pump if the noise come from air filter box area in which case you could just temporarily disconnect it. If you have VCDS you might be able to test it using output tests or as Audi call them final control diagnosis.
Old 30th December 2014, 08:31 PM
Revs are constant - no change, it still revs drives etc., no misfire
I don't have VCDS - but may take car off the road and order it!
Old 30th December 2014, 08:34 PM
I did have a fault code for that a while back (from a hand held diagnostic) - the noise sounds higher up than the air filter box
Noise seems to resonate more when I take the oil filler cap off....
Old 31st December 2014, 02:32 PM
It does sound like some sort of electric fan is constantly on as Ainarssems says.
I assume the electric radiator fan is not turning when you hear the noise?
Old 31st December 2014, 03:45 PM
No fan is not on. I am nor driving it today and am ordering VCDS for myself to see if that points me in the right direction!
Old 31st December 2014, 04:06 PM
steamship steamship is online now
Could it possibly be the engine block breather valve giving up the ghost?
Old 1st January 2015, 08:30 AM
Where do I find this and how do I test it?
Old 1st January 2015, 10:59 AM
I think you're onto something there! perhaps the rubber diaphragm has failed and is vibrating as it lets air out?
Its the black plastic UFO type object at the back of the engine.
Here it is in a picture I borrowed from another forum member's post as it shows the engine bay without covers.
It is easy to remove by jubilee clip or the Audi type clip, but I'm not sure if its safe to run the engine without it or with the rubber hose plugged to test if the noise stops?
Probably ok for a minute or two, as its just a sprung rubber diaphragm to let some crankcase pressure out when it builds up enough to be able to open the diaphragm.
This is how it looks inside:
http://forums.quattroworld.com/a8/threads/8649.phtml
