Old 9th July 2015, 07:33 PM
I think detection of the TV unit is automatic; if it's not there the option doesn't appear. I'd check wiring and power to the tuner first.
And if in doubt a full power cycle may reset it.
There is no option in the RNS-D configuration for TV and when I added that input to mine it just appeared in the cycle.
Old 10th July 2015, 06:42 AM
goldsax goldsax is offline
Thanks for the reply.
Full power reset meaning ...unplug the unit per supply and reconnect?
Thanks raj
Old 10th July 2015, 08:00 AM
Find the relevant fuse and pull it for a short time then re-enter the code; I've had to do that a couple of times in the past to reset my RNS.
Not 100% sure where the fuse is, on PF it was in the boot above the battery.
Just likely to be easier than taking the RNS out of the dash.
Old 13th July 2015, 06:40 AM
i have the keys and was earlier to remove the unit and left it unplugged for 30 minutes and reconnected . i tried this 3 times.
it made no difference.
the radio stations were still remembered when reconnected.
i thought it would reset the whole system to factory setting. but apparently not.
so is there a way to reset to factory settings?
many thanks
raj
Old 13th July 2015, 10:08 AM
andycaca andycaca is offline
unplug the tv unit in the boot and then plug it back in again?
2001 S8 D2
Old 13th July 2015, 10:03 PM
thanks for the reply.
still no joy.
tried searching the net, for hard reset and found that there is a way to ‘hack’ into the unit.
but feel a bit uneasy is the post warned that it could go wrong.
i wonder why its so hard/impossible to do a hard reset..
Old 14th July 2015, 06:25 AM
mannyo mannyo is offline
Have you checked the fuse for the TV Tuner?
Manny
Past
