VCDS (aka Vagcom) For all your electronic debug / diag advice queries and mods. |
Hi All,
I was asked to scan an A8 3.0 TDI for a reasonabvly local enthusiast. Here is the resultant log. I have edited the owner details even though I have his permission to publish this. Any comments? Tuesday,23,October,2018,14:40:04:58733 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86 VCDS Version: 18.2.1.2 Data version: 20180518 DS287.1 www.Ross-Tech.com VIN: WAUZZZ4E46N0xxxxx License Plate: WV05xxx Mileage: 242610km-150750mi Repair Order: #01 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 1E 25 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 72 76 77 VIN: WAUZZZ4E46N013222 Mileage: 242610km-150750miles 00-Steering Angle Sensor -- Status: Sporadic communication error 1000 01-Engine -- Status: Malfunction 1010 02-Auto Trans -- Status: Malfunction 1010 03-ABS Brakes -- Status: Malfunction 1010 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: Malfunction 1010 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 1010 16-Steering wheel -- Status: Malfunction 1010 17-Instruments -- Status: Malfunction 0010 18-Aux. Heat -- Status: Malfunction 1010 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: Malfunction 0010 25-Immobilizer -- Status: Malfunction 0010 28-HVAC, Rear -- Status: Malfunction 0010 34-Level Control -- Status: Malfunction 1010 36-Seat Mem. Drvr -- Status: Malfunction 1010 37-Navigation -- Status: Malfunction 1010 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: Malfunction 1010 55-Headlight Range -- Status: Malfunction 0010 56-Radio -- Status: Malfunction 0010 57-TV Tuner -- Status: Malfunction 0010 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: Malfunction 0010 72-Door, Rear Right -- Status: Malfunction 0010 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: Malfunction 1010 ------------------------------------------------------------------------------- Address 01: Engine Labels: 059-907-401-ASB.clb Part No SW: 4E0 910 401 Q HW: 4E0 907 401 C Component: 3.0L V6TDI G000AG 0030 Revision: --H01--- Serial number: AUX3Z0E9375520 Coding: 0011973 Shop #: WSC 02313 785 00200 VCID: 2959D191801C4F0C50-807C 8 Faults Found: 000260 - Mass Air Flow Sensor (G70) P0104 - 001 - Intermittent - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 212488 km Time Indication: 0 Date: 2018.02.22 Time: 00:03:26 Freeze Frame: RPM: 273 /min Torque: 234.0 Nm Speed: 0.0 km/h Duty Cycle: 80.9 % Voltage: 10.03 V Absolute Pres.: 999.6 mbar Mass Air / Rev.: 0.0 mg/str 000258 - Mass Air Flow Sensor (G70) P0102 - 001 - Signal too Low - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 212488 km Time Indication: 0 Date: 2018.02.22 Time: 00:03:29 Freeze Frame: RPM: 819 /min Torque: 210.6 Nm Speed: 0.0 km/h Duty Cycle: 80.9 % Voltage: 12.62 V Absolute Pres.: 1009.8 mbar Mass Air / Rev.: 487.6 mg/str 004195 - Fuel Pressure Regulation P1063 - 004 - Control Range Not Reached - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 212488 km Time Indication: 0 Date: 2018.02.23 Time: 00:05:20 Freeze Frame: RPM: 798 /min Torque: 230.1 Nm Speed: 0.0 km/h Duty Cycle: 1.0 % Voltage: 13.91 V Pressure: 184.6 bar Duty Cycle: 51.3 % 005705 - Powertrain Data Bus P1649 - 001 - Missing Message from ABS Controller - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 5 Reset counter: 255 Mileage: 0 km Time Indication: 0 Date: 2018.03.26 Time: 00:00:00 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h (no units): 24.0 Voltage: 11.02 V (no units): 1.0 000568 - Manifold Pressure / Boost Sensor (G31) P0238 - 001 - Signal too High - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Time Indication: 0 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 4.980 V Voltage: 10.49 V Absolute Pres.: 979.2 mbar Temperature: -90.0°C 000275 - Intake Air Temp. Sensor (G42) P0113 - 001 - Signal too High - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Time Indication: 0 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 10.49 V Absolute Pres.: 1009.8 mbar Temperature: 108.0°C Temperature: 10.8°C 000566 - Manifold Pressure / Boost Sensor (G31) P0236 - 001 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 0 km Time Indication: 0 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 4.980 V Voltage: 5.70 V Absolute Pres.: 979.2 mbar Temperature: -90.0°C 001393 - Brake Switch (F) P0571 - 001 - Implausible Signal - MIL ON Freeze Frame: Fault Status: 11100001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 14:02:47 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 10.72 V (no units): 0.0 (no units): 0.0 Bin. Bits: 00000100 Readiness: 0 3 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4E0 910 156 F HW: 09L 927 156 Component: AG6 09L 3.0lTDI RdW 0090 Revision: --H01--- Serial number: 4002839 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2541DDA1EC046B6C74-8070 8 Faults Found: 18259 - Powertrain Data Bus P1851 - 000 - Missing Message from ABS Controller - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 39 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:49 Freeze Frame: RPM: 0 /min RPM: 0 /min RPM: 0 /min (no units): 30.0 (no units): 25.0 Temperature: 4.0°C T.B. Angle: 0.0° 18271 - Powertrain Data Bus P1863 - 001 - Missing Message from Steering Angle Sensor - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 0 Fault Frequency: 2 Reset counter: 39 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:03:35 18290 - Powertrain Data Bus P1882 - 001 - Missing Message from Electric Parking Brake Controller - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 39 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:04:00 18289 - Powertrain Data Bus: Missing Message P1881 - 001 - Acceleration Request - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 39 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:04:00 18275 - Powertrain Data Bus P1867 - 001 - Missing Message from Steering Wheel (J527) - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 39 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:50 16944 - System Voltage P0560 - 000 - Malfunction - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 0 Fault Frequency: 2 Reset counter: 40 Mileage: 0 km Time Indication: 0 18288 - Powertrain Data Bus P1880 - 001 - Missing Message from Diagnostic Gateway - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 0 Fault Frequency: 1 Reset counter: 39 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:48 18265 - Load Signal P1857 - 000 - Error Message from ECU - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 0 Fault Frequency: 9 Reset counter: 40 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:13:04 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H44 0510 Coding: 0008357 Shop #: WSC 00001 000 00000 VCID: 224BC6BDFD2A9C5411-8076 2 Faults Found: 18265 - Load Signal P1857 - 000 - Error Message from ECU - Intermittent 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H07 0160 Revision: 01604707 Serial number: AUX3Z0E9375520 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58BFA455EBF606843F-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 7 Faults Found: 02229 - Transmission Control Module (TCM); Immobilizer Data not Adapted 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 255 Mileage: 221584 km Time Indication: 0 Date: 2016.04.06 Time: 00:00:18 02241 - Engine Control Module; Immobilizer Data not Adapted 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 255 Mileage: 221584 km Time Indication: 0 Date: 2016.04.06 Time: 00:00:18 02226 - Engine Control Module (ECM) 2; Immobilizer Data not Adapted 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 255 Mileage: 221584 km Time Indication: 0 Date: 2016.04.06 Time: 00:00:20 00192 - Rear Left Door Handle Touch Sensor (G417) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 0 Reset counter: 76 Mileage: 0 km Time Indication: 0 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:56 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 12 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:06 00166 - Access/Start Authorization Switch (E415) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 1 Fault Frequency: 14 Reset counter: 116 Mileage: 212304 km Time Indication: 0 Date: 2018.02.16 Time: 00:01:22 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory BFS H08 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 3670112 Shop #: WSC 00000 785 00200 VCID: 2345C3B9E230955C1A-8076 2 Faults Found: 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242612 km Time Indication: 0 Date: 2017.10.22 Time: 13:50:28 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 76 Mileage: 0 km Time Indication: 0 Date: 2005.01.01 Time: 00:00:00 ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 730 Q HW: 4E0 035 729 A Component: Interfacebox H43 2120 Revision: 00000000 Serial number: 300BJ057548940 Coding: 0000002 Shop #: WSC 00000 785 00200 VCID: 2E53228DB9F2283485-807A Subsystem 1 - Part No: 4E0 910 609 C Component: Bedienteil MMI H42 0100 Subsystem 2 - Serial number: 318BP057515187 Subsystem 3 - Serial number: 7401.02.0500000000218B0158ÿ Subsystem 4 - Serial number: 8B0158ÿ 6 Faults Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 76 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:57 01964 - Control Module for Seat & Steering Column Memory (J136) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 4 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:26:40 01310 - Level Control System Control Module (J197) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:03:03 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 4 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:03:29 Freeze Frame: Bin. Bits: 01 02103 - Control Module 2 for Vehicle Electrical System (J520) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:03:57 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 3 Reset counter: 116 Time Indication: 15 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: User\4E0-910-043.lbl Part No SW: 4E0 910 043 B HW: 4E0 820 043 D Component: KLIMAAUTOMAT 016 0400 Revision: 00000030 Serial number: 00000000062140 Coding: 1132625 Shop #: WSC 02311 785 00200 VCID: 1C37F845DF4EAAA4DB-8048 13 Faults Found: 00716 - Air recirculation Flap Positioning Motor (V113) 003 - Mechanical Failure Freeze Frame: Fault Status: 01100011 Fault Priority: 3 Fault Frequency: 209 Reset counter: 76 Mileage: 241771 km Time Indication: 0 Date: 2017.09.20 Time: 10:16:18 Freeze Frame: Voltage: 13.50 V Temperature: 21.0°C (no units): 192.0 (no units): 34.0 Temperature: 40.0°C 01592 - Air Quality Sensor (G238) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 18 Mileage: 241771 km Time Indication: 0 Date: 2017.09.20 Time: 10:16:19 Freeze Frame: Temperature: 22.0°C 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 115 Mileage: 241775 km Time Indication: 0 Date: 2017.09.20 Time: 12:11:30 Freeze Frame: Voltage: 13.40 V 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 140 Reset counter: 102 Mileage: 241828 km Time Indication: 0 Date: 2017.09.21 Time: 09:34:28 Freeze Frame: Voltage: 13.70 V 00003 - Control Module 003 - Mechanical Failure - Intermittent Freeze Frame: Fault Status: 00100011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 115 Mileage: 242599 km Time Indication: 0 Date: 2017.10.20 Time: 20:45:31 Freeze Frame: Temperature: 20.0°C 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 12 Reset counter: 76 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:10 Freeze Frame: Bin. Bits: 00011111 00455 - Control Module for Access and Start Control; Comfort CAN (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 115 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:31 Freeze Frame: Bin. Bits: 00011000 00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 3 Reset counter: 115 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:41 Freeze Frame: Bin. Bits: 00011000 01853 - Heated Seat; Left Front (Z45) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 115 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:33 Freeze Frame: Temperature: 25.0°C 01854 - Heated Seat; Front Right (Z46) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 115 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:33 Freeze Frame: Temperature: 25.0°C 01855 - Temperature Sensor for Heated Seat; Left Front (G344) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 115 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:33 Freeze Frame: Temperature: 25.0°C 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 115 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:33 Freeze Frame: Voltage: 11.30 V 01206 - Signal for Duration of Ignition Off Time 014 - Defective Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 115 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:33 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No HW: 4E0 907 279 L Component: WWS NO RESPONSE Coding: 0123001 Shop #: WSC 02313 785 00200 VCID: 55A1AD61FCE43BEC24-8000 Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH10 0050 Coding: 00139548 Shop #: WSC 02313 2 Faults Found: 01520 - Rain and Light Recognition Sensor (G397) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.28 Time: 23:20:37 00908 - Control Module for Wiper Motor 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 1 Fault Frequency: 31 Reset counter: 76 Mileage: 242614 km Time Indication: 0 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 G Component: Airbag 8.4E+ H10 0940 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 63C583B9A2B0D55C5A-8036 8 Faults Found: 01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145) 009 - Open or Short to Ground - Intermittent 00588 - Airbag Igniter; Driver Side (N95) 001 - Upper Limit Exceeded - Intermittent - MIL ON 01587 - Igniter 2 for Airbag; Drivers Side (N250) 001 - Upper Limit Exceeded - Intermittent - MIL ON 01218 - Side Airbag Igniter; Passenger Side (N200) 001 - Upper Limit Exceeded - Intermittent - MIL ON 01217 - Side Airbag Igniter; Driver Side (N199) 001 - Upper Limit Exceeded - Intermittent - MIL ON 00591 - Seat Belt Switch; Driver (E24) 010 - Open or Short to Plus - Intermittent 00592 - Seat Belt Switch; Passenger (E25) 010 - Open or Short to Plus - Intermittent 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H13 0040 Coding: 0112141 Shop #: WSC 02311 785 00200 VCID: 65C19DA1AC84AB6CB4-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H05 0080 5 Faults Found: 01426 - Controls in Steering Wheel (E221) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 66 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:23:55 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded Freeze Frame: Fault Status: 01100010 Fault Priority: 6 Fault Frequency: 23 Reset counter: 255 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 14:08:15 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 4 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 14:18:53 00455 - Control Module for Access and Start Control; Comfort CAN (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 10 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:27 01317 - Control Module in Instrument Cluster (J285) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 116 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 950 F HW: 4E0 920 950 F Component: KOMBIINSTR. VDO H53 0200 Revision: D05 Serial number: AUDID3E1000779 Coding: 0000413 Shop #: WSC 00011 067 57207 VCID: 275DD7A99608797C46-8072 2 Faults Found: 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 00000011 Fault Priority: 1 Fault Frequency: 51 Reset counter: 76 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:51 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 4 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:04:19 ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 A HW: 4E0 815 069 E Component: Heizgeraet H07 0100 Revision: 0000000B Serial number: 00000009006406 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 1A3BFE5DD57AD494C9-804E 5 Faults Found: 01406 - No Flame 000 - - 02251 - Heater Unit Locked 000 - - 33477 - Terminal Status Unknown - 004 - - Intermittent 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent 02095 - Component Protection Active 000 - - ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4E0-910-468.clb Part No SW: 4E0 910 468 B HW: 4E0 907 468 E Component: Gateway H10 0080 Revision: 10 Serial number: 19003052170092 Coding: FCFE7FDE2B3504 Shop #: WSC 02313 785 00200 VCID: 275DD7A99608797C46-8072 14 Faults Found: 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 30 Reset counter: 116 Mileage: 241790 km Time Indication: 0 Date: 2017.09.20 Time: 12:41:33 01310 - Level Control System Control Module (J197) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:06:33 01300 - Control Module for Navigation with CD-Rom (J401) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 5 Reset counter: 116 Mileage: 241847 km Time Indication: 0 Date: 2017.09.21 Time: 10:02:04 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:06:33 01315 - Transmission Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:06:33 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:06:33 00473 - Control Module for Elect. Park/Hand Brake (J540) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:06:33 01321 - Control Module for Airbags (J234) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:06:33 00778 - Steering Angle Sensor (G85) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 4 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:06:33 01207 - Control Module for Auxiliary Heater (J364) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 10:08:11 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 14:18:55 01964 - Control Module for Seat & Steering Column Memory (J136) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 10 Reset counter: 116 Mileage: 0 km Time Indication: 0 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 10 Reset counter: 116 Mileage: 0 km Time Indication: 0 00461 - Control Module for Seat Memory; Passenger (J521) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 95 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:03 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBG8229001 Shop #: WSC 00000 000 00000 VCID: 1C37F845DF4EAAA4DB-8048 4 Faults Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 2 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:06:08 00474 - Control Module for Immobilizer 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 4 Fault Frequency: 83 Reset counter: 76 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:08:12 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 2 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 14:18:50 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 4 Fault Frequency: 92 Reset counter: 76 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:08:12 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H07 0160 Revision: 01604707 Serial number: AUX3Z0E9375520 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58BFA455EBF606843F-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 7 Faults Found: 02229 - Transmission Control Module (TCM); Immobilizer Data not Adapted 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 255 Mileage: 221584 km Time Indication: 0 Date: 2016.04.06 Time: 00:00:18 02241 - Engine Control Module; Immobilizer Data not Adapted 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 255 Mileage: 221584 km Time Indication: 0 Date: 2016.04.06 Time: 00:00:18 02226 - Engine Control Module (ECM) 2; Immobilizer Data not Adapted 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 255 Mileage: 221584 km Time Indication: 0 Date: 2016.04.06 Time: 00:00:20 00192 - Rear Left Door Handle Touch Sensor (G417) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 0 Reset counter: 76 Mileage: 0 km Time Indication: 0 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:56 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 12 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:06 00166 - Access/Start Authorization Switch (E415) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 1 Fault Frequency: 14 Reset counter: 116 Mileage: 212304 km Time Indication: 0 Date: 2018.02.16 Time: 00:01:22 ------------------------------------------------------------------------------- Address 28: HVAC, Rear Labels: User\4E0-910-158.lbl Part No SW: 4E0 910 158 HW: 4E0 919 158 A Component: KLIMA-STG. FOND 015 0210 Revision: 00000017 Serial number: 00000000025011 Coding: 0000000 Shop #: WSC 00000 000 00000 VCID: 61C989B1B8ACC74C48-8034 3 Faults Found: 01864 - Air Outlet Motor; Rear Right (V219) 003 - Mechanical Failure - Intermittent 00455 - Control Module for Access and Start Control; Comfort CAN (J518) 004 - No Signal/Communication - Intermittent 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 H HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 4480 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 285FD4959B1676044F-807C 5 Faults Found: 01598 - Drive Battery Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 4 Fault Frequency: 23 Reset counter: 116 Mileage: 0 km Time Indication: 0 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 3 Reset counter: 116 Mileage: 0 km Time Indication: 0 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 4 Reset counter: 168 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:03 00778 - Steering Angle Sensor (G85) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 7 Reset counter: 168 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:06:39 01398 - Signal Conductor for Central Locking; Doors Open 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 168 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:35 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory FS H08 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 3670122 Shop #: WSC 00000 785 00200 VCID: 2345C3B9E230955C1A-8076 2 Faults Found: 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 3 Reset counter: 116 Mileage: 242612 km Time Indication: 0 Date: 2017.10.22 Time: 13:50:28 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Reset counter: 76 Mileage: 0 km Time Indication: 0 Date: 2005.01.01 Time: 00:00:00 ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 887 Q HW: 4E0 919 887 C Component: MNS ECE H44 0850 Revision: 00000000 Serial number: 305BE057572015 Shop #: WSC 02313 785 00200 VCID: 3B751BD97A80CD9C32-806E 2 Faults Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 4 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 13:52:15 02445 - Disk Drive Initialization Error 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 5 Fault Frequency: 1 Reset counter: 0 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:03:36 ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H02 0090 Serial number: 00000426700008 Coding: 0036004 Shop #: WSC 02313 785 00200 VCID: 1D31F541C454A3AC2C-8048 2 Faults Found: 01331 - Door Control Module; Driver Side (J386) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 116 Mileage: 242612 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:00 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 3 Reset counter: 116 Mileage: 242612 km Time Indication: 0 Date: 2004.03.25 Time: 00:02:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 B Component: Türsteuer.FS BRM002 0060 Coding: 0028590 Shop #: WSC 02311 785 00200 VCID: 204FCCB5F3268E4407-8074 4 Faults Found: 00913 - Window Regulator Switch; Front Right Driver (E81) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 255 Mileage: 241952 km Time Indication: 0 Date: 2017.09.23 Time: 10:04:02 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 116 Mileage: 0 km Time Indication: 0 02126 - Central Locking Button; Exterior Door Handle 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 5 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:06 00461 - Control Module for Seat Memory; Passenger (J521) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:10 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H04 0040 Revision: 00400004 Serial number: W040503010096 Coding: 0004857 Shop #: WSC 02313 785 00200 VCID: 275DD7A99608797C46-8072 Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P27H08 0090 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H03 0020 10 Faults Found: 00892 - Switch for Trunk Closing Cylinder (F248) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 186 Reset counter: 76 Mileage: 242226 km Time Indication: 0 Date: 2017.10.03 Time: 09:12:58 01503 - Bulb for 3rd Brake Light (M25) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 8 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:18 00576 - Terminal 15 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 34 Reset counter: 116 Mileage: 0 km Time Indication: 0 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 187 Reset counter: 76 Time Indication: 1 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 8 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:34 00474 - Control Module for Immobilizer 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 4 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:35 01316 - ABS Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 12 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:05:52 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 116 Mileage: 0 km Time Indication: 0 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 15 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:04 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 80 Reset counter: 76 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:06 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 K HW: 4E0 035 223 A Component: DSP-Amp.-High H13 0440 Revision: PROD_01 Serial number: 00000000011655 Coding: 0000013 Shop #: WSC 02313 785 00200 VCID: 2541DDA1EC046B6C74-8070 3 Faults Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 2 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 14:18:50 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 5 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 13:49:46 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:32 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H09 0040 Revision: Serial number: 00000000056371 Coding: 0010101 Shop #: WSC 02313 785 00200 VCID: 1E33F24DC952B8B435-804A 5 Faults Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 3 Fault Frequency: 12 Reset counter: 116 Mileage: 242612 km Time Indication: 0 Date: 2017.10.22 Time: 14:18:00 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 116 Mileage: 262140 km Time Indication: 0 Date: 2018.07.10 Time: 20:19:00 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 3 Fault Frequency: 74 Reset counter: 116 Mileage: 242612 km Time Indication: 0 Date: 2017.10.22 Time: 13:50:00 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 9 Reset counter: 116 Mileage: 0 km Time Indication: 0 Date: 2023.06.06 Time: 00:00:00 02095 - Component Protection Active 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 254 Reset counter: 76 Mileage: 242612 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:00 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 B Component: Türsteuer.BF BRM002 0060 Coding: 0028590 Shop #: WSC 02311 785 00200 VCID: 204FCCB5F3268E4407-8074 5 Faults Found: 02111 - Motor for Window Regulator 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 4 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2017.10.22 Time: 14:14:10 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 5 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2017.10.22 Time: 14:15:46 01308 - Control Module for Roof Electronics (J528) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 116 Mileage: 0 km Time Indication: 0 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 116 Mileage: 0 km Time Indication: 0 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 116 Mileage: 0 km Time Indication: 0 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 D HW: 4E0 907 801 B Component: EPB A4EC0230 H03 0230 Revision: --H03--- Coding: 0000221 Shop #: WSC 00468 210 91510 VCID: 204FCCB5F3268E4407-8074 5 Faults Found: 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 116 Time Indication: 0 Freeze Frame: Voltage: 10.97 V Count: 247 01315 - Transmission Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 116 Time Indication: 0 Freeze Frame: Voltage: 8.80 V Count: 243 00576 - Terminal 15 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 116 Time Indication: 0 Freeze Frame: Voltage: 8.28 V Count: 41 02432 - Supply Voltage for Left Parking Brake Motor (V282) 012 - Electrical Fault in Circuit - MIL ON Freeze Frame: Fault Status: 11111100 Fault Priority: 1 Fault Frequency: 5 Reset counter: 76 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:34 Freeze Frame: Voltage: 12.01 V Count: 86 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 76 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:56 Freeze Frame: Voltage: 10.97 V Count: 61 ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4E0-910-357.lbl Part No SW: 4E0 910 357 HW: 4E0 907 357 Component: Pre-AFS H01 0040 Revision: 00000001 Serial number: Coding: 0000002 Shop #: WSC 02311 785 00200 VCID: 62CB86BDBDAADC5451-8036 5 Faults Found: 00455 - Control Module for Access and Start Control; Comfort CAN (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 116 Mileage: 242616 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:26 00070 - Starting Battery Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 0 Reset counter: 40 Mileage: 8 km Time Indication: 0 00778 - Steering Angle Sensor (G85) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 0 Reset counter: 40 Mileage: 242616 km Time Indication: 0 Date: 2004.03.25 Time: 00:06:38 00255 - ABS Valves 015 - Cannot Be Tested at this Time - MIL ON Freeze Frame: Fault Status: 11101111 Fault Priority: 2 Fault Frequency: 0 Reset counter: 40 Mileage: 242616 km Time Indication: 0 Date: 2004.03.25 Time: 00:04:41 02233 - Left Headlight Power Output Stage (J667) 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 76 Mileage: 242616 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:03 ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 L HW: 4E0 035 541 E Component: TUNER EU/US/RDW H42 0560 Revision: 00000000 Serial number: 396CV057505268 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2959D191801C4F0C50-807C 1 Fault Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 175 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:04:53 ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: 4E0-910-146.clb Part No SW: 4E0 910 146 E HW: 4E0 919 146 C Component: TV analog TUNER H14 0270 Revision: 00000022 Serial number: 00000000003528 Coding: 0000003 Shop #: WSC 00000 785 00200 VCID: 2345C3B9E230955C1A-8076 2 Faults Found: 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 5 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 13:53:06 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 3 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 14:19:04 ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0510 Revision: 00000000 Serial number: 00000000006444 Shop #: WSC 00171 210 91005 VCID: 204FCCB5F3268E4407-8074 Subsystem 1 - Part No: 4E0 915 105 Component: von TU3 7023479471 Coding: 344530393135313035202054553337303233343739343731 Shop #: WSC 12345 123 45725 5 Faults Found: 02274 - Quiescent Current Stage 3 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:38:06 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 01:31:31 02255 - Voltage Measuring Lead from Vbat 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 4 Fault Frequency: 10 Reset counter: 76 Time Indication: 0 Date: 2004.03.25 Time: 00:00:35 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00110010 Fault Priority: 1 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2017.10.22 Time: 14:18:55 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00110100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:26 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 C Component: Türsteuer.HL BRM002 0060 Coding: 0028590 Shop #: WSC 02311 785 00200 VCID: 1E33F24DC952B8B435-804A 2 Faults Found: 02111 - Motor for Window Regulator 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:06:14 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:06:14 ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 C Component: Türsteuer.HR BRM002 0060 Coding: 0028590 Shop #: WSC 02311 785 00200 VCID: 1E33F24DC952B8B435-804A 5 Faults Found: 01308 - Control Module for Roof Electronics (J528) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 116 Mileage: 0 km Time Indication: 0 01299 - Diagnostic Interface for Data Bus (J533) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 116 Mileage: 0 km Time Indication: 0 01320 - Control Module for Climatronic (J255) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 116 Mileage: 0 km Time Indication: 0 02111 - Motor for Window Regulator 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:06:14 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 116 Mileage: 242608 km Time Indication: 0 Date: 2004.03.25 Time: 00:06:14 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 A HW: 4E0 919 283 B Component: Parkhilfe 8-Kan H12 0020 Revision: --.--.-- Serial number: 08720505401201 Coding: 0001008 Shop #: WSC 02313 785 00200 VCID: 2149C9B1F82C874C08-8074 10 Faults Found: 01546 - Sensor for Parking Aid; Rear Mid-Left (G204) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 2 Reset counter: 32 Mileage: 241933 km Time Indication: 0 Date: 2017.09.22 Time: 15:42:43 01628 - Sensor for Parking-Aid; Front Mid-Left (G254) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 3 Reset counter: 20 Mileage: 241774 km Time Indication: 0 Date: 2017.09.20 Time: 10:26:31 01627 - Sensor for Parking-Aid; Front Mid-Right (G253) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 3 Reset counter: 29 Mileage: 241774 km Time Indication: 0 Date: 2017.09.20 Time: 10:26:31 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 6 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:02:20 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 6 Fault Frequency: 2 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:05:48 01336 - Company Data Bus for Comfort System 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 1 Reset counter: 116 Mileage: 242614 km Time Indication: 0 00456 - Control Module for Access and Start Control (J518) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 18 Reset counter: 116 Mileage: 242614 km Time Indication: 0 00576 - Terminal 15 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 116 Mileage: 0 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:00 01545 - Sensor for Parking Aid; Rear Left (G203) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 14 Reset counter: 76 Mileage: 241774 km Time Indication: 0 Date: 2017.09.20 Time: 10:26:30 01627 - Sensor for Parking-Aid; Front Mid-Right (G253) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 4 Reset counter: 116 Mileage: 242614 km Time Indication: 0 Date: 2004.03.25 Time: 00:01:28 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 F HW: 4E0 862 335 Component: Handyvorb2 H10 0580 Revision: 00000000 Serial number: 00000007541090 Coding: 0010900 Shop #: WSC 02313 785 00200 VCID: 2541DDA1EC046B6C74-8070 2 Faults Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 2 Reset counter: 41 Time Indication: 15 00446 - Function Limitation due to Under-Voltage 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 116 Time Indication: 15 End-------------------------(Elapsed Time: 03:43)--------------------------
Reading through that list, there seems to be two quite distinct instances of something significant happening to throw so many error codes. There is the one on 2004.03.25 which also managed to get quite a few Component Protection errors, and then there is the second one on 2007.10.22. I suspect battery issues of some sort.
As others would suggest, I'd save the log (assumed you have), and then clear all the codes. There is the option to clear ALL codes, but probably wiser to go into each block and clear them (will take longer, but better). Then have the owner drive around for a few days and then get another scan done, and see what's left.
My thoughts exactly. Save that log, clear ALL the codes by going into each module individually.
Then scan again and save that and scan again after a decent amount of use. Move forwards from there.
Interesting. Can't say I've even see that many errors before. Like, every single module....
Flat battery aside, which its clearly had, its hard to imagine a routine set of faults that would cause this level of error reporting. I would wonder if something has been chatting / interfering or confusing the can bus, causing the modules to all fail to talk to each other at some point. The key thing is most of the failures are 'intermittent' which means it was a fault, and now isn't, so should clear, but weird it happened in the first place... That might also explain how component protection has kicked in, if the modules couldn't talk to the cluster properly at some point to establish the ID of the car. I suspect with a good charge in the battery, most of the faults will clear, then you'll be left with the usual suspects to resolve. If all the errors light up again like this, then its going to be an interesting journey to diagnose....
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
Does the car actually have any issues to prompt the scan Ray?
Otherwise it's a power problem. Make sure the battery and alternator are good, reset and move on...
Cheers Marty ____________________ Current: 2001 Audi S8 - Brilliant Black with Black interior, C5 RS6 rims (whenever I actually put them on...), Solar Sunroof, Tinted side and rear glass, RNS-D, Grom, Bose, clunky old phone in arm rest! 2002 Audi S8 - Project Replacement head coming arrived ![]() Silver with Black interior. All features as the '01, with the 'S' mode auto shifter. Dodgey rear tint (need to find a way to get rid of that). Family: 2009 Volvo XC90 V8 R Design - has a louder more obnoxious exhaust than the S8, sounds great! Love this thing - Q7 was double the price, and certainly not double the car! Sold: 1997 Audi A4 - Hamilton's Club Sport, Achat Grey (will miss the old girl) |
Hopefully as other posts suggest, a flat battery or power failure has thrown up the majority of these faults.
we've got a Renault trafic in the workshop at the moment - dash it lit up like a Christmas tree. Kept going in to limp mode or simply not starting. Run our computer over it and had very similar results with almost every CAN module showing power failures/communication errors. Clearing them would not get rid so the fault is current/ongoing. Started in the engine bay to look for wiring faults or bad connections......the pic says a thousand words. Wiring has obviously been bodged by a garage at some point and wrapped up in insulating tape. There has been no attempt to even connect the wires properly. Just stripped and twisted together! Sorry for the post hijack...as you were
Daily drive: 2016 Infiniti QX70.....a car that's even more complicated than my last Infiniti FX to modify ![]() Current 'Project': VW Crafter CR50 4 berth camper van Previous 'Projects': 2006 Subaru Legacy Spec 'B' 3.0R, 1994 Ex-MOD Land Rover Defender, now "civilianised". 2000 Audi S8 FL www.whall.co.uk |
Ray, what state is the car in, is this the chappy who is currently unable to use his 8?
If it drives I’d be inclined to do as others have suggested, save, clear, new battery, code battery in and suck it and see.
2010 A8 SE Executive 4.2 FSI D4 2007 Mini Cooper S R56 2008 D3, gone, but not forgotten after 9 years and 90k. |
Apologies, I have been rather busy over the weekend and could not access the forum.
Now for the explanation after I have wetted your appetites. ![]() This car has had a few problems, Johnmed was correct in his guess as to ownership. Started with engine cutting out when the tank was down to approximately half full, resolved by reseating the fuel pump. This was quickly followed by a wet carpet in the passenger footwell. With the help of our sponsors the owner was able to replace a load of items (I have no idea what or how many) and eventually managed to get the engine running (I think). He then asked me to do a scan which you have all seen. I think it is every fault possible on every module, but then I am no expert. At that point I had run out of time so could not start to clear it down. I should be able to visit him tomorrow and will update this thread on what happens.
An old thread I know
But did you get to the bottom of what was the cause My a8 has similar
Audi A8 d3 4.2 petrol 2004 Blue |
![]() Quote:
I'd suggest following the instructions given to Ray, with a couple of other suggestions on top. Provide the original scan if you still have it, as well as an updated scan after clearing and driving it. It also helps if you can provide symptoms of the issues experienced, as well as details of anything you've done to try and resolve the issues. The more information you can provide, the easier it is to eliminate possible causes.
