Old 12th November 2022, 04:05 PM
Garry1's Avatar
Garry1 Garry1 is offline
Default A8 d3 odd scan
New to this stuff
Car came up a battery low
And stopped mmi from booting
Mmi only comes on and off again
Changed battery and car runs fine but nothing working
Coded battery and still the same
Cleared codes and errors returned after a drive
Saturday,12,November,2022,15:04:51:08597
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
VIN: WAUZZZ4E84N015326 License Plate:
Mileage: 115590km-71824mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 19 1E 25 34 36 37 38 42 46
47 4F 52 53 56 57 5E 61 62 65 72 76
VIN: WAUZZZ4E84N015326 Mileage: 115590km-71824miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Cannot be reached 1100
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
57-TV Tuner -- Status: Cannot be reached 1100
5E-Ctrl Head LR -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 1010
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 Q HW: 4E0 907 560
Component: 4.2L V8/5V G 0030
Revision: 00000000 Serial number: AUX3Z0CN127976
Coding: 0011773
Shop #: WSC 00411 210 96661
VCID: 2F381B434B1F5523428-807A
VINID: 9D196AAAA1152047800450C21865F1B97A
4 Faults Found:
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V RdW 0110
Revision: 00000001 Serial number: 0025352
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 2412E46F12D9E67BAFA-8070
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 M
Component: ESP 5.7 allrad H44 0500
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 221EE27708CDE84BDD6-8076
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131
Component: FBS AUDID3 H03 0130
Revision: 01303703 Serial number: AUX3Z0CN127976
Coding: 0264192
Shop #: WSC 02311 785 00200
VCID: 58EA809F1E11729BF32-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Shop #: WSC 00000 785 00200
VCID: 2310E77317D7E143D60-8076
1 Fault Found:
01964 - Control Module for Seat & Steering Column Memory (J136)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 191
Mileage: 114512 km
Time Indication: 0
Date: 2003.02.27
Time: 03:52:35
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 016 0240
Revision: 00000022 Serial number: 00000000030648
Coding: 1069057
VCID: 5AEE9A97601D608BC56-800E
4 Faults Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 185
Mileage: 115594 km
Time Indication: 0
Date: 2003.03.20
Time: 01:16:02
Freeze Frame:
Temperature: 38.0°C
00819 - High Pressure Sensor (G65)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 185
Mileage: 115581 km
Time Indication: 0
Date: 2003.03.19
Time: 23:24:24
01858 - Air Outlet Sensor; Right Center (G348)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 189
Reset counter: 224
Mileage: 111614 km
Time Indication: 0
Date: 2021.11.25
Time: 11:08:44
01857 - Air Outlet Sensor; Middle Left (G347)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 224
Mileage: 115190 km
Time Indication: 0
Date: 2003.05.22
Time: 01:51:50
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0000001
VCID: 2A0E0A5770FD300B956-807E
Subsystem 1 - Part No: 4E2 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02311
2 Faults Found:
00908 - Control Module for Wiper Motor
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 115191 km
Time Indication: 0
Date: 2003.06.20
Time: 23:08:25
02510 - Steering Column Adjustment
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 254
Reset counter: 78
Mileage: 22878 km
Time Indication: 0
Date: 2009.05.01
Time: 09:37:15
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
VCID: 6390A7735757A143960-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112141
VCID: 6594B96B5963DF73784-8030
Component: Lenkradmodul H03 0070
1 Fault Found:
00886 - Turn Signal Switch (E2)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 215
Mileage: 114626 km
Time Indication: 0
Date: 2003.03.25
Time: 13:08:02
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 CX
Component: KOMBIINSTR. VDO H42 0070
Revision: D08 Serial number: AUDID3C6000184
Coding: 0016403
Shop #: WSC 00411 210 175099
VCID: 5CE29C8F6A299EBBD7A-8008
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0070
Revision: 07 Serial number: 1400303A0625E4
Coding: FCFE5BDD2B2505
Shop #: WSC 00976 210 82602
3 Faults Found:
00470 - Company Comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 13
Reset counter: 217
Mileage: 113937 km
Time Indication: 0
Date: 2022.06.13
Time: 16:33:31
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 193
Mileage: 114605 km
Time Indication: 0
Date: 2003.03.11
Time: 02:11:43
00384 - Optical Databus
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Reset counter: 185
Mileage: 115190 km
Time Indication: 0
Date: 2003.05.15
Time: 02:23:45
Address 1E: Media Player 2
Cannot be reached
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0264192
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 2514F96B19E31F73B84-8070
4 Faults Found:
00778 - Steering Angle Sensor (G85)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 5
Reset counter: 215
Mileage: 114500 km
Time Indication: 0
Date: 2003.02.27
Time: 00:36:47
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 103
Reset counter: 225
Mileage: 113783 km
Time Indication: 0
Date: 2022.05.25
Time: 10:59:14
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 2
Reset counter: 203
Mileage: 114821 km
Time Indication: 0
Date: 2003.03.29
Time: 05:21:47
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 206
Mileage: 115191 km
Time Indication: 0
Date: 2003.06.20
Time: 23:08:27
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H07 0060
Coding: 4063330
1 Fault Found:
00668 - Supply Voltage Terminal 30
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 115572 km
Time Indication: 0
Date: 2003.03.19
Time: 04:39:56
Address 37: Navigation
Cannot be reached
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0090
Serial number: 00000331300033
Coding: 0035840
VCID: 1D64D18B31B3D7B3E04-8048
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 193
Mileage: 114604 km
Time Indication: 0
Date: 2003.03.11
Time: 02:11:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 802
Component: Türsteuer.FS BRM005 0110
Coding: 0028450
VCID: 5EE696877C358CABB9E-800A
1 Fault Found:
00913 - Window Regulator Switch; Front Right Driver (E81)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 114512 km
Time Indication: 0
Date: 2003.03.01
Time: 01:19:22
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040311180041
Coding: 0000217
VCID: 2708F36363EF0D638A8-8072
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
4 Faults Found:
01504 - Bulb for License-Plate Light (X)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 193
Mileage: 114499 km
Time Indication: 0
Date: 2022.06.20
Time: 13:39:19
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Reset counter: 185
Mileage: 68437 km
Time Indication: 0
Date: 2013.03.03
Time: 14:23:29
01308 - Control Module for Roof Electronics (J528)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 193
Mileage: 114608 km
Time Indication: 0
Date: 2003.03.11
Time: 02:27:50
00892 - Switch for Trunk Closing Cylinder (F248)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 225
Mileage: 115379 km
Time Indication: 0
Date: 2003.06.27
Time: 23:58:12
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000027974
Coding: 0010101
VCID: 1E66D6873CB5CCABF9E-804A
1 Fault Found:
01797 - Power Steering Hydraulic Pressure Valve (N119/N315)
Freeze Frame:
Fault Priority: 2
Reset counter: 225
Mileage: 111100 km
Time Indication: 0
Date: 2021.10.19
Time: 13:58:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 801
Component: Türsteuer.BF BRM005 0110
Coding: 0028450
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 HW: 4E0 907 801
Component: EPB A01H019 H01 0190
Coding: 0000531
Shop #: WSC 00022 210 75084
1 Fault Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01110000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 130
Time Indication: 0
Freeze Frame:
Voltage: 12.01 V
Count: 61
Address 56: Radio
Cannot be reached
Address 57: TV Tuner
Cannot be reached
Address 5E: Ctrl Head LR
Cannot be reached
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 A HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0230
Revision: 00000000 Serial number: 00000005308435
Subsystem 1 - Part No: 000 915 105 AK
Component: von JCB 1310310223
Coding: 303030393135313035414B4A434231333130333130323233
Shop #: WSC 12345 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM005 0110
Coding: 0028450
VCID: 5DE4918B713397B3A04-8008
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0252127
VCID: 5F98AB837B3F85A3B28-800A
2 Faults Found:
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 253
Reset counter: 185
Mileage: 111570 km
Time Indication: 0
Date: 2021.11.20
Time: 14:43:56
Freeze Frame:
Speed: 0.0 km/h
Temperature: 12.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 164
Mileage: 38994 km
Time Indication: 0
Date: 2011.02.22
Time: 15:57:33
Freeze Frame:
Speed: 38.0 km/h
Temperature: 9.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM005 0110
Coding: 0028450
1 Fault Found:
02115 - Locking Unit for Central Locking
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 0 km
Time Indication: 0
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H11 0010
Revision: --.--.-- Serial number: 00000332500058
Coding: 0001008
VCID: 211CED7B0DCBF353C4C-8074
1 Fault Found:
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 72
Reset counter: 176
Mileage: 96733 km
Time Indication: 0
Date: 2015.02.12
Time: 06:51:15
End----------(Elapsed Time: 01:43, VBatt start/end: 12.4V/12.4V)-----------
Saturday,12,November,2022,15:31:34:08597
www.Ross-Tech.com
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 1E 25 34 36 37 38
42 46 47 4F 52 53 56 57 5E 61 62 65 72 76
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
16-Steering wheel -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
Coding: 0011773
Readiness: 0110 1101
Coding: 0000001
Coding: 0008597
Coding: 0264192
Component: ELV XXXX
Coding: 4063328
Cannot be reached
Coding: 1069057
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 185
Mileage: 115594 km
Time Indication: 0
Date: 2003.03.20
Time: 01:16:02
Freeze Frame:
Temperature: 38.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 185
Mileage: 115581 km
Time Indication: 0
Date: 2003.03.19
Time: 23:24:24
Freeze Frame:
Fault Priority: 3
Reset counter: 224
Mileage: 111614 km
Time Indication: 0
Date: 2021.11.25
Time: 11:08:44
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 224
Mileage: 115190 km
Time Indication: 0
Date: 2003.05.22
Time: 01:51:50
Coding: 0000001
Coding: 00000030
Shop #: WSC 02311
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 3
Reset counter: 78
Mileage: 22878 km
Time Indication: 0
Date: 2009.05.01
Time: 09:37:15
Address 0E: Media Player 1
Cannot be reached
Address 0F: Digital Radio
Cannot be reached
Coding: 0431707
Coding: 0112141
Coding: 0016403
Coding: FCFE5BDD3B2D05
Cannot be reached
Coding: 0264192
Component: ELV XXXX
Coding: 0015510
Coding: 4063330
Cannot be reached
Coding: 0035840
Coding: 0028450
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 191
Mileage: 114512 km
Time Indication: 0
Date: 2003.03.01
Time: 01:19:22
Coding: 0000217
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 185
Mileage: 68437 km
Time Indication: 0
Date: 2013.03.03
Time: 14:23:29
Cannot be reached
Coding: 0010101
Coding: 0028450
Coding: 0000531
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 130
Time Indication: 0
Freeze Frame:
Voltage: 12.01 V
Count: 61
Address 56: Radio
Cannot be reached
Cannot be reached
Cannot be reached
Coding: 0028450
Coding: 0252127
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 185
Mileage: 115595 km
Time Indication: 0
Date: 2003.03.20
Time: 02:31:25
Freeze Frame:
Speed: 0.0 km/h
Temperature: 14.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0028450
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 187
Mileage: 0 km
Time Indication: 0
Coding: 0001008
End----------(Elapsed Time: 01:41, VBatt start/end: 12.3V/12.3V)-----------
Audi A8 d3 4.2 petrol 2004
Blue
Old 12th November 2022, 06:06 PM
Have you also checked the car for water ingress due to blocked drains, as this will cause no end of headaches? Anyway, here's what I can suggest:
Address 02: Odd that the summary shows a Malfunction yet detail says 'no fault code', so just ignore
Address 07 / 0E / 0F / 1E / 37 / 47 / 56 / 57 / 5E - I suspect these are all connected. Check out the following video and see if these modules have a tick against them. You can watch the entire video or just from where I have it starting (module 13 in the video): https://youtu.be/txzhjGfTqqI?t=115
Address 08: Old date. Try clearing from within module
Address 09: Old date. Try clearing from within module
Address 42: Old date. Try clearing from within module
Address 46: Common on all Audis. Alarm is knackered, usually by corroded battery
Address 53: Check out the following thread: https://forums.ross-tech.com/index.php?threads/14402/
Address 65: Old date. Try clearing from within module. Error shows 'System switched off'. Go into MMI and check if disabled. If it is, try enabling again and see if error persists, although I wouldn't have thought disabling it would throw an error code. If the sensors are dead (internal batteries), maybe that's why it was disabled
Address 72: Possible faulty motor, but could be wiring as error is intermittent. Check out the following thread: https://forums.ross-tech.com/index.php?threads/2009/
Also check this video where they strip the lock mechanism down and spray it with contact cleaner: https://youtu.be/HlYGjZbVkDg?t=419
Old 12th November 2022, 06:21 PM
My immediate reaction (as noted by Sean/Steamship) is that actually you DIDN'T clear the codes successfully.
The global clear doesn't always work, so I ALWAYS clear codes module by module and go back to check. THEN after a clear(ish/er) scan go for a drive and scan again.
Old 12th November 2022, 06:43 PM
Garry1's Avatar
Thanks for the replys
Checked the boot and some water in the wheel well
The boot lid had water in it
I think its getting in through the boot panel
Where the handle is
Will get it resealed
Also car has no sunroof carpet is dry inside
Also date and time in the car is 2003
Blue
Old 12th November 2022, 09:41 PM
sarg sarg is offline
I'm confused by your signature
2004 4.2 S8?
If it's a 2004, it's not an S8 with a 4.2 block
Do you mean a 2004 D3 A8 4.2?
2019 BMW M5 (my daily driver)
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 13th November 2022, 07:26 AM
Garry1's Avatar
2004 4.2 S8?
A8 d3 2004
Was a typo I never noticed this sorry
Changed it now
Blue
Old 13th November 2022, 08:48 AM
Three things:
1. Water in the boot lid is most likely a result of water ingress through the light clusters, as over time the seals perish and in some cases the outer lense covering also start to separate from the rest of the unit.
2. Two other possible sources of water ingress are due to blockages in the a/c drains either side of the transmission tunnel and also blocked drains in the plenum chamber. These have been discussed on the forum.
3. If that is the case, it makes sense to correct the date and time so that any errors generated will have the correct date/time, as it's essential to know when it happened. Also, three of the dates in the second scan are after 2003, so this just results in confusion as to what happened and when.
My course of action would be as follows:
. Sort out the date/time
. Go through the process shown in the video to see if the group of modules (07 etc) are selected
. Perform a scan
. Go into each module that has thrown an error and attempt to clear the codes
. Note down any module number that fails to clear the codes
. Go for a drive
. Rescan car
. Post scan along with details of any modules that failed to clear codes as performed above
Old 13th November 2022, 09:01 AM
Garry1's Avatar
The date and time
I haven't got a clue how to change it as the buttons on the wheel or dash not working
Blue
Old 13th November 2022, 04:10 PM
The date and time
Silly me. The group of modules (Address 07 / 0E / 0F / 1E / 37 / 47 / 56 / 57 / 5E) are all related and the MMI controls are part of all that. There is an optical diagnostic test you can run in VCDS to see if you can identify what may be causing the issue here. They all run on a fibre optic bus, so if there is a fault in any one part, the entire system doesn't work. You can buy fibre optic bridge loops which allow you to bypass a particular module, as a way of testing if that particular module is faulty or not.
Check out the following page on the Ross-Tech site on what to do with that test:
https://www.ross-tech.com/vcds/tour/optical-bus.php
If you need a fibre optic bridge loop, you can buy cheap ones from the likes of eBay for around a fiver, as the OEM ones are around £40. Here's a link to one such example:
https://www.ebay.co.uk/itm/132847813657
Old 27th November 2022, 12:47 PM
Garry1's Avatar
Question
Still can't get the mmi to work
Done connection check and broken in 3 places
Waiting on jumper plug coming
The radio did work most of the week
But just stopped again
Date and time still 2003
Blue
