Old 6th October 2023, 11:54 AM
Default Anyone near Chelmsford with VCDS?
Would anyone be willing to look at a car in Chelmsford for me and if possible give it a scan with VCDS?
Remuneration of expenses and beer tokens available.
TiA
Mike
Old 8th October 2023, 02:59 PM
Conquistador's Avatar
Chelmsfordian here! Rather good timing because a friend of mine has just bought a TT and wanted a few things enabled and tinkered with. I've dug out my old HEXCAN cable but can't locate the little software disc for it and can't seem to download the old 12.12 version of the software online which ye olde cable works with.
I can post this in the VCDS section too, but would you or anybody else be able to point me to wherever I could download the 12.12 version? Rosstech site posts all the versions but each download link for the relevant version just automatically downloads the very latest version.
If I can get it working, and if you still need a local car scanned and looked over, then I'm more than happy to help.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 8th October 2023, 04:27 PM
Are you sure it won't work with the latest VCDS? No harm in trying...
Exactly which model cable is it though, maybe post a photo? USB, serial?
Old 8th October 2023, 04:31 PM
Is it a genuine rosstech cable? If not it’ll need the hacked old software to work……if genuine as Andrew says it should work with the latest version
Old 8th October 2023, 04:34 PM
Thanks for the offer Oli, but it's gone. So we can stand down in that one. No going to target one in Birmingham!
Old 9th October 2023, 10:10 AM
On the other side of the cable it just says 'VCDS 12.12' and has a status LED.
From what I remember it has the ability to connect to as many VIN numbers / vehicles as I like but won't work beyond version 12.12. Ultimately, I think it was a cloned cable but have a download link from a very helpful PM which looks promising.
I've also read on a couple of sites that the cable doesn't always work beyond 2015 cars, so we'll see if it works with this 65 plate TT!
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 9th October 2023, 10:35 AM
That looks identical to mine, although mine was supplied by a verified company in the UK, and as such doesn't look genuine as it has their stickers on it, and not Ross-Tech. Mine is also unlimited VINs which I bought around 2013-2014, although the most recent vehicle I've scanned with it is 2011.
The Ross-Tech site itself lists that it works up to 2015, although it also states that it may also work on some newer models:
https://www.ross-tech.com/vag-com/ol...rfaces/huc.php
It's almost certainly a clone and will probably only work with the hacked software that came with it.
Genuine cables typically have a serial number label, a "sold by" label and NO software version label as they don't need a specific version.
Old 9th October 2023, 01:00 PM
The ross-tech sticker looks genuine - but could be faked - this link provides info on the interface and its limitations
Presume you've tried installing the current software version and it's not worked? There's a driver download link in the one above that might help.
I've got an old hex+can cable which works on my 2015 Golf, but didn't work on my neighbour's T-roc
ETA - the more I look at it, the more I think that's a clone. The other side of my cable says 'Genuine Ross-Tech', has a different 'pimple' arrangement, and has security screws rather than Philips
Old 9th October 2023, 03:25 PM
Oh it's definitely a cloned cable. I bought it from a certain disgraced ex-forum member for £30 if I remember correctly, as did a few others. It came with a 12.12 installation mini disc which annoyingly I can't find, but it used to be fine for doing the odd adaption on my S8s.
Tried with the latest version but it doesn't like it.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
