Old 11th August 2014, 03:53 PM
Default Where Can I Buy The Proper Audi Connectors?
I've finally splashed out and bought the parts for retrofitting the rear and side blinds to my D2. Where can I buy the proper connector for the blind switch, and is there a part number for it?
I've checked in the version of ETKA that I have and can find the part number of the blind switch (4D0 959 903B), but not the wired connector.
Old 11th August 2014, 04:33 PM
I presume that's the smaller FL switch; I'd ask A8parts if they have the connector with some wire.
If you use the larger "old school" switch (it can go in the blank hole to the right of the steering wheel) then normal blade connectors will suffice.
But don't you need a wiring loom as well, wouldn't that include the necessary?
Old 11th August 2014, 05:40 PM
I queried that the first time I called them about it some months ago, but it was suggested I buy the entire loom for the car, rather than just that part. It's taken me this long to buy, so another little while won't matter
