Old 11th December 2014, 02:32 PM
Default For Sale: HP Mini 110 with VCDS, Elsa & ETKA
Having bought a second hand X200 tablet for using with the car, I now have a HP Mini 110 to sell. This is classed as a Netbook, and as such isn't really designed to be your main computer. I bought it at the time because it was affordable, compact and had a SD card reader - handy for copying your photos from your camera (my main use then).
It currently comes with Windows 7 Professional installed. The only other programs installed are as follows:
Elsa 5.1
ETKA 7.3
VCDS 11.11 - This uses a clone cable, and can't be upgraded to the current version.
It also comes with the standard power supply, an in-car power adaptor and the cloned VCDS cable. The only other noticeable thing about it is that it has a US style keyboard - position of " and @ swapped, and $ instead of £.
I'm looking for £60 all in. That's £50 for the computer and hopefully £10 to cover postage costs.
For those interested, pictures are attached, and these are the specs:
Processor type - Intel Atom N270
Processor speed - 1600.0 MHz
Display size - 10.1 inches
Resolution - 1024 x 576 pixels
External Monitor Interface - Integrated
Primary Graphics Chipset - Intel 945 Express Chipset
Drive size - 160.0 GB
SD Card reader
Battery Type - Lithium ion
Audio - Microphone In
Audio - Headphone Out
USB - Universal Serial Bus Port (x3)
Ethernet Type - 10/100 Mbps
Wireless connection - 802.11 g
Memory size - 1024.0 MB
Memory type - DDR2 SDRAM
Memory speed - 800.0 MHz
Width 10.3 inches
Depth 6.8 inches
Height 1.4 inches
Weight 3.2 pounds
Speakers - Mono
ID:	9706   Click image for larger version
ID:	9707   Click image for larger version
ID:	9708   Click image for larger version
ID:	9709   Click image for larger version
