Old 26th January 2014, 07:39 AM
Oli18's Avatar
Oli18 Oli18 is offline
Default How to change headlight angle for mainland Europe?
Hi guys,
As the title says, how can I change the bi-xenons on my D3 to point them in the right direction for driving in mainland Europe?
Is there a VCDS setting to do that?
Oli
Audi A8/S8 D2 Flickr Group
Old 26th January 2014, 09:21 AM
Yes, VCDS depending on whether Adaptive click the relevant adaptation link...
http://wiki.ross-tech.com/wiki/index...udi_A8/S8_(4E)
Last edited by snapdragon; 26th January 2014 at 01:53 PM. Reason: missing bracket thanks adrian
Old 26th January 2014, 09:38 AM
You need that missing ) from the link above
Old 15th October 2019, 03:17 PM
ulfilias ulfilias is offline
Channel 010: Tourist Solution
When driving in countries where driving is performed on the opposite side as in the native country the headlights must be changed over to avoid blinding the oncoming traffic. When active/enabled the Fault Code 02988 will be stored.
0 = Disabled
1 = Enabled
Note: Only supported for 8P0-907-357-C @ 0020 or newer! Earlier versions require a mechanical Adjustment as described in the Factory Repair Manual.
Going to Belgium in November, so was checking this out in good time and
Hmm....Just had a look in VCDS and chanel 010 is not available.
I've 4E0-907-357-C in a 2005 D3 A8
Any ideas on Mechanical Adjustment in the Factory Repair Manual ???
Current :
Previous :
Also :
Old 16th October 2019, 07:27 AM
Somerandomguy's Avatar
Here is the page from the manual - never managed it myself, I usually just stick a piece of gaffer tape on the light as its quicker and easier
2004 A8 3.0 TDI Sport Brilliant Black
Came with: Black Valcona/Alcantara Leather, KESSY, rear blind, flappy paddle gear change, Phone Prep, TV
Added:Bluetooth, AMI, Hybrid TV, Parking plus, Ski hatch, towbar, DAB, Umbrella Holder, Reversing camera, Auto lights, Wheel refurb
Things to fix: Turbo fault, power drain
Old 16th October 2019, 08:27 AM
My old A6 (late 1990s vintage) had a simple flip lever that took seconds to do, so you could do it on the ferry/train. Seems like a good idea that got lost somewhere.
Old 16th October 2019, 09:25 AM
My PF S8 was similar, the only confusion I found (and I no longer remember the answer) was that I think the levers were opposite directions left and right, so one was up while the other was down and vice-versa.
I do remember that I had to test it at home and write it down before driving to Le Mans with a carful of people, luggage and camping gear back in 2009!
Old 16th October 2019, 11:28 AM
Wheel liner....Eeep. Nice quick and easy, then - I can see buying the plastic light things as whilst gaffer tape may work, i can't see police etc being happy if they pull you!
Having a quick look and i wasn't sure it looked that similar - Is that the Xenon Plus ???
Current :
Previous :
Also :
Old 16th October 2019, 12:25 PM
Most gas discharge headlights have a lower cutoff than traditional filament bulbs anyway, so you don’t dazzle oncoming traffic as much when driving on the ‘wrong’ side of the road
Is there nothing on d3s to put a flap down on the cutoff from the MMI? My S5 does, but only shows up when stationary
Tags
audi a8, europe, headlight
