Old 11th February 2010, 12:53 PM
B@fink B@fink is offline
i'm gonna need a pit for this one.......undone all the 3 bolts on the mounting but its either going to need the sub frame dropping, the engine raising 2" or the 2 cast alloy sections bolted onto the side of the box taking off. Anyone know if the bolts are into blind tappings? I don't want to take the 2 cast alloy sections off, only to have the box fluid join me on the outside...... Have had to put it all back together until i get to a pit or ramp. Another fine plan shot down in flames!
Old 18th February 2010, 06:50 PM
twang has been exorcised. few trapped fingers but i got it done, 2 new bushes fitted.
Old 18th February 2010, 07:04 PM
Oli18's Avatar
Oli18 Oli18 is offline
Nice one mate. Is that all the noise now sorted too?
Audi A8/S8 D2 Flickr Group
Old 18th February 2010, 07:13 PM
apart from tyre noise she's pretty much silent. Deep JOY!
There was one particular part of the journey home i always got the noise (a dip in the road where a cable had been buried just before a junction stop) and all week shes been perfect. One of the bushes had a snapped elastic band (not really an issue) and the other one was very squashy and damp, not sure if they are hydraulic but if they are it was leaking! Happy the engine isn't moving now, was worried about cracking the 'zausts, now i just got the 40mph hiccup to solve....1 down, 1 to go.
Old 18th February 2010, 07:21 PM
thebluewhale's Avatar
Great result. 1 out of 2 ain't bad.
Did you take any pics for a 'How To'?
Old 18th February 2010, 07:41 PM
i was all up for a few piccys (indeed i took a snap of the blighters in preparation) but it was such a pain getting them out all ideas of a carefuly crafted article went straight out of the window! Just be happy they don't die regularly so it wouldnt be used the access for the nuts and bolts is not too bad with a wheel off but lifting the engine up at the tail is tricky. Without direct undercar access (pit or ramp) it'd be all but impossible, and even then the bushes need to be "convinced" a bit.
