Old 11th February 2012, 03:06 PM
sundayrider sundayrider is offline
Default Air Filter
Thought I'd do a simple job today and replace the air filter but one thing led to another, hence my other thread.
Got three of the screws out but the third is solid, any ideas on how to remove? Its the right hand screw at the front of the air box.
So I thought I'd take the plastic cover off next to the air filter but that screw just spins (bottom left hand corner next to the washer filler), again any advice please?
Old 11th February 2012, 05:16 PM
47p2's Avatar
47p2 47p2 is offline
Can you not remove the air duct pipe to give more access?
Nite Blue 3.0L SE Quattro
Old 11th February 2012, 05:30 PM
Sorry photo taken after Id put it all back together. Think I will have to get the mole grips back of my son.
Old 11th February 2012, 10:39 PM
Oli18's Avatar
Oli18 Oli18 is offline
I had this issue on my previous 8 and in the end i had to use a dremel to cut it. Not what you wanted to hear i'm sure but that's how i got around it.
Oli
Audi A8/S8 D2 Flickr Group
Old 12th February 2012, 01:43 PM
Dremal purchased and filter replaced.
Thanks for the advice.
Old 12th February 2012, 02:31 PM
47p2's Avatar
Make sure you clean up the mess the Dremel has left as they are small pieces of metal and they will cause rust on anything they land on
Old 12th February 2012, 03:35 PM
Old 16th February 2012, 11:53 AM
johnds8 johnds8 is offline
Default .
I was going to say drill or dremel.
I ended up replacing mine with M6 titanium bolts. They won't be rusting like the OEM!!
John
