Old 14th March 2010, 12:15 PM
Mr K Mr K is offline
Default Boot Struts
How strong should they be? When I press the boot release button on mine it litterally just unlocks it. I would like it to open too, as per most mercs and BMWs.
Is it meant to open right up? If not has anyone found a stronger strut to make it pop open?
Old 14th March 2010, 05:04 PM
mine just opens the lock too but not the boot so I'd be interested in the answer to this too. On my A4 it opens the lock and then the boot rises too
Old 14th March 2010, 07:10 PM
bircham
Guest
Posts: n/a
Same with my A8 - the button opens the boot but then I have to manually lift the boot lid up.
Jon
Old 14th March 2010, 07:50 PM
I don't think the D2 came with the auto boot option and it was an extra on the D3 (I don't have it )
Old 14th March 2010, 07:55 PM
Correct, not available on the D2, although I guess its do-able if you were to use some sort of hydraulic/pneumatic arms in place of the factory ones...
The D3 auto boot is actually quite useful, I've used it a few times to open the boot by the time I walk back to the car, throw my bags in, hit the close button and go and get in the drivers seat.... Really saves time !
Old 14th March 2010, 10:01 PM
Im not after auto open/close, just with stiffer struts when you hit unlock they would lift it all the way open right? my brothers MX5 was like this, when you unlocked it on the key it opened 1/3 of the way, simply using the gas struts.
I see no reason that with a stronger strut it wont open all the way.
so when your struggling with lots of stuff in your arms you can just press the unlock button on the key, and it will open right up. Im happy to close it 'manually' again after.
Old 15th March 2010, 04:16 PM
Oli18's Avatar
Oli18 Oli18 is offline
There are a few that have done this already on Mk6 and Mk5 golfs...
MK5 http://www.youtube.com/watch?v=Iv9Y_ZgZxr4
MK6 including 'how-to' http://www.youtube.com/watch?v=b3rIN...eature=related
http://www.golfmk6.com/forums/showthread.php?p=31448
Looks like there have been some issues making it work but some have managed. They did need to turn around some of the brackets to make the angle of opening easier....
Lovely mod....who'll be the first to have a go?
Audi A8/S8 D2 Flickr Group
Old 15th March 2010, 04:35 PM
Oli18's Avatar
Another example - Passat:
http://www.solovag.es/viewtopic.php?f=15&t=534
http://www.youtube.com/watch?v=-1Vw6t0FC5Y
Old 16th March 2010, 07:23 AM
bircham
Guest
Posts: n/a
I wonder what boot struts would do the job? I would have thought that any of the VAG boot struts would do - perhaps the ones from those Passats?
Jon
