Old 28th November 2016, 06:35 AM
Oli18's Avatar
Oli18 Oli18 is offline
Default D3 Parasitic battery drain
Hi all,
It's been a while since i've posted but i've kept an eye out on the forum and been enjoying the 8 in the meantime.
For about 2-3 months now, I've been suffering from a parasatic battery drain which means that if the car is left for 2 weeks without driving, it struggles to start. If left a week, i also notice it's down but a bit better.
Below is the last scan I did at the end of October which i was hoping might give a clue. I can't remember if i cleared the fault codes afterwards or not but i can do another scan later this week to check.
I haven't changed the battery and am reluctant to do so without eliminating the other potential causes first and wanted to check what methodology others go through to find out where a drain might be coming from.
For reference, the following are known to me:
- TPMS has been disabled
- Soft close driver handle stopped working a few years back
- Rain sensor replaced in March - i can clear codes to see if it re-appears
- Auxiliary parking heating has never worked
- Driver identification component protection has always had this
Your advice is greatly appreciated.
Oli
OBDeleven data log
Date: 2016-10-30 10:47
VIN: WAUZZZ4E26N019357
Car: Audi A8
Year: 2006
Mileage: 206060 KM
02 Transmission Control Module
System description: AG6 09E 4,2lTDI RdW
Software version: 0030
Hardware number: 4E1910156P
Serial number: 0076831
Coding: 0000001
Trouble codes:
No trouble codes found
05 Kessy
System description: FBS AUDID3 H10
Software version: 0190
Hardware number: 4E0910131
Serial number: AUX3Z0F0383869
Coding: 0412672
Subsystems:
System description: ELV
Software number: XXXXXXXXXXX
Software version: XXXX
Trouble codes:
00179 - Driver access/start authorization antenna Upper limit exceeded
static
00668 - Vehicle voltage terminal 30 Lower limit not reached
Intermittent
06 Seat Adjustment Passenger Side
System description: Sitzmemory BFS H02
Software version: 0010
Hardware number: 4E0910760D
Serial number: 5DS 008 795-03
Coding: 4063328
Trouble codes:
01725 - Longitud. adjustment switch, backward, driver seat mechanical malfunction
Intermittent
01724 - Longit. adjust. switch, forward, frt. pass. seat mechanical malfunction
Intermittent
01970 - Depth adjustment button, backward mechanical malfunction
Intermittent
01969 - Depth adjustment button, forward mechanical malfunction
Intermittent
07 Display Control Unit
System description: Interfacebox H43
Software version: 5570
Hardware number: 4E0910769Q
Serial number: 300AC067562505
Coding: 0000002
Subsystems:
System description: Bedienteil MMI H42
Software number: 4E0910609A
Software version: 0020
Trouble codes:
08 Air Conditioning
System description: KLIMAAUTOMAT 016
Software version: 0400
Hardware number: 4E0910043B
Serial number: 00000000088042
Coding: 0022563
Trouble codes:
09 Central Electrics
System description: ILM Fahrer H14
Software version: 0230
Hardware number: 4E0910279Q
Coding: 0133122
Subsystems:
System description: Wischer WWS D3 H50
Software number: 4E2910113B
Software version: 0420
Coding: 0000036
System description: REGENLICHTSENSORH11
Software number: 4E0910557
Software version: 0050
Coding: 0139548
Trouble codes:
01520 - Rain/light recognition sensor Lower limit not reached
Intermittent
0E Media Player Position 1
System description: CD-Changer H44
Software version: 0470
Hardware number: 4E0910111F
Serial number: AUZ5ZBF8049216
Trouble codes:
11 Engine Control Module 2
System description: 4.2L V8TDI A000AGSª
Software version: 0070
Hardware number: 4E1910409A
Coding: 0011773
Trouble codes:
P1849 - Read DTC memory of transmission CM Implausible signal
Intermittent
13 Adaptive Cruise Control
System description: ABSTANDSREGELUNGH03
Hardware number: 4E0910561F
Coding: 0011154
Trouble codes:
01316 - Brake control module Please read DTC
Intermittent
15 Airbag
System description: Airbag 9.41 H12
Software version: 3610
Hardware number: 4E0910655D
Serial number: 0037P000DLH0
Coding: 0431707
Trouble codes:
16 Steering Column Electronics
System description: Lenksäulenmodul H13
Software version: 0040
Hardware number: 4E0910549
Coding: 0112151
Subsystems:
System description: Lenkradmodul H07
Software version: 0080
Trouble codes:
17 Dash Board
System description: KOMBIINSTR. VDO H70
Software version: 0410
Hardware number: 4E0910980N
Serial number: AUDID3F0000091
Coding: 0000403
Trouble codes:
16346 - Control module Faulty
static
18 Auxiliary Parking Heater
System description: Heizgeraet H07
Software version: 0110
Hardware number: 4E0910105A
Serial number: 00000009006406
Coding: 0000001
Trouble codes:
01412 - Glow plug with flame monitoring Implausible signal
static
02251 - Heater unit locked
static
19 Gateway
System description: Gateway H11
Software version: 0090
Hardware number: 4E0910468B
Serial number: 19004061088029
Long coding: FEFFFBDF2B7504
Trouble codes:
01325 - Tire Pressure Monitoring Control Module No signal/communication
static
01044 - Control module incorrectly coded
static
00467 - TV tuner No signal/communication
Intermittent
1D Driver Identification
System description: FPI_1 H06
Software version: 0060
Hardware number: 4E0910218
Serial number: 11082004063652
Trouble codes:
02095 - Component protection active
static
00446 - Function limitation due to insufficient voltage Lower limit not reached
Intermittent
1E Media Player Position 2
System description: SG ext.Player
Software number: 4E0035785F
Software version: 0850
Hardware number: 4E0035785C
Hardware version: H20
Long coding: 010000
Trouble codes:
25 Immobilizer
Coding: 0412672
Subsystems:
Trouble codes:
static
Intermittent
34 Ride Control System
System description: LUFTFDR.-CDC H06
Software version: 6310
Hardware number: 4E0910553J
Coding: 0015510
Trouble codes:
01400 - Level control system Upper limit exceeded
Intermittent
01398 - Signal wiring from central locking - doors open No signal/communication
Intermittent
01772 - Sig. wire from level ctrl pressure sensor Implausible signal
static
01577 - Switch-off due to excessive temperature Upper limit exceeded
Intermittent
36 Seat Adjustment Driver Side
System description: Sitzmemory FS H02
Coding: 4063342
Trouble codes:
37 Navigation
System description: MNS ECE H47
Software version: 1060
Hardware number: 4E0910888P
Serial number: 364AS067525548
Trouble codes:
02261 - Data medium Faulty
Intermittent
02927 - DVD read error
Intermittent
Audi A8/S8 D2 Flickr Group
Old 28th November 2016, 08:45 AM
Takemetothepub Takemetothepub is offline
Has the battery to your knowledge ever been changed?
If not I'd suggest it's just time, like tyres they really are a consumable. As the cold weather creeps in dying batteries start to show they are dying.
2005 6.0 W12 Quattro SWB - Need an OPEC membership to run it!
Old 28th November 2016, 08:47 AM
FYI in May I replaced my battery in my W12 with this one and been very happy with it.
http://www.ebay.co.uk/itm/Lucas-LP-0...EAAOSwfcVUIv1l
Old 28th November 2016, 10:06 AM
Hello Oli
wheres engine 1 in the scan , does it have battery regulation on the vehicle .
Follow earth lead off the battery .....does it go to module before it terminates to earth .
Could be a battery like already said ,but could also have a drain on it .
Ideally you need to put a amps meter in series between the battery lead and see how much draw you have as the draw rate gives you a clue as to whatever may be staying awake or pulling low amps out
Old 28th November 2016, 11:40 AM
One of the functions of the BEM is to cut off power rails when neccessary to preserve battery change. 2006 MY BEMs didn't suffer the problems of earlier ones.
I have had similar issues and fitted an AGM battery and recoded and only had problems since when leaving the ignition on by mistake. I don't think two weeks is that bad if it still starts (even reluctantly), afterall it has an alarm and keyless entry to run.
I have also found that leaving VCDS plugged in when turning off the car and then unplugging it seems to cause a battery drain. Always close the controller and unplug while the ignition is still on now.
Old 28th November 2016, 11:47 AM
Should battery energy monitor of been in the scan Snap ? .............. is on my car anyhow .....me leaving my auxillary burner going for to long often puts quiecent volts under codes in there ......cars is lovely and toasty in the morn though hehehe
Old 28th November 2016, 03:29 PM
Turbo Tony's Avatar
Hmm... I have the same problem on my car and I'm watching this thread with interest.
Audi think it was caused by a faulty EPB motor. It's been changed now but I've not had the car back so I can test.
Storytellers Villa Orlando
2008 Audi S8
Old 28th November 2016, 03:47 PM
1781cc 1781cc is offline
You still don't have a car?
Old 28th November 2016, 04:49 PM
Turbo Tony's Avatar
Nope. I don't want to hijack this thread but Audi have been chasing a ridiculously minor knocking sound for a grand total of 13 weeks. I've called them today for an update and I'm waiting for them to get back to me.
2008 Audi S8
Old 28th November 2016, 06:55 PM
There's many faults in there. I'd suspect quite a few of them are old and related to low battery but the one that jumps out to me is the over temp of the air compressor.
That tells me you quite possibly have a leak in the suspension somewhere. If there is a leak then the suspension will be trying to level it's self periodically while your away from the car.
I don't know however if it will run the compressor or just use what's in the accumulator.
The other thing that jumps out is the instrument cluster fault. It's vague but I have seen on two occasions now where a faulty cluster keeps the can bus awake while the car is locked and that flattens the battery.
You can easily tell if the can bus is awake by looking to see if the lights around the gear shift are lit up at night when the car has been locked for more than 10 mins
