  #35
Old 11th December 2019, 01:07 PM
OK, initial job done with help from my retired garage-owner friend.
We tested when the short-circuited terminals there were "live" and it was only when the ignition key is in the start position, so no possibility of battery drain etc.
And we of course were able to start the car in any gear lever position, though it's extremely unlikely I'd do that by accident given the interlocks between gear lever movement, key removal and brake pedal. I've left the relay bypass wire in for now. Though everything is all "hanging out" in the footwell.
We did this just as the weather turned again, so at some later date I'll go back and test more thoroughly, checking continuity through the F125 as the gear lever is moved. Also, when Franks relay arrives I'll do some testing on both mine and his to see if it's possibly a relay issue.
(Orange drains and putting everything back tidily will all be done at the same time)
Incidentally I think the R circuit in the F125 is OK as that also powers my reversing camera and that does come on.
And the rear parking sensors also fire up, they probably get triggered by the same circuit though I don't know for sure.
Thanks everyone for your help. This place is invaluable.
