Old 17th December 2009, 03:40 PM
Its the main beam that is the bi-xenon bit. The normal dipped headlight mechanically lifts up in order to give you a xenon full beam, where the normal xenons use a regular Halogen for the main beam and flash. The Bi-xenons have a seperate halogen bulb that is used only for flash, hence the wiring is quite a bit different between the two....
I share your opinion that the normal xenons do actually look more 'xenony' in most peoples eyes, and to the uneducated they might not appreciate the bi-xenon as much, but when you're bombing down a B road in the the pitch black, the bi-xenon will look best from the drivers seat
