Originally Posted by Delboy
Question for you all.
How much data is passed over internet to run a miner.
Was thinking if possible to run on boat I work on which has power on tap but internet is via sat.
The internet usage is very little, I have not done any tests but I understand you need less than 5kB/s with less than 2GB/month usage but low latency plays part which could be a problem with satellite. Probably not a problem with high power miner which runs at high difficulty but if you just run a test with like a 1 GPU PC you might get your shares rejected if they are late. Obviuously cannot say for sure as I have not tested.
