Old 29th April 2018, 09:00 PM
Been mostly fiddling and fettling this week. Now that most of the big jobs are out of the way it was time to do something which has been bugging me for a while.
Because of the LPG tank, the boot carpet doesn't fit any more. This is a, most uncomfortable when working in the boot, and b, a most excellent tool-trap when things fall under the tank! I should imagine its also quite vexing if you want to use the boot too!
Nicht gut.
Cut a piece of 10mm plywood to fit the space.
Cut it in to two pieces. This is where the new floor will 'hinge'. The leading edge of this is tapered to lead the new carpet on to the original floor.
Painted the visible surfaces on the top
Sprayed the underside with sound-deadening paint
Cut the new carpet using a spare as a template
Made a support brace at the front end of the spare wheel well. This will support the front end of the lifting piece of the new floor.
The front piece of the new board sits on top of the support and is held in place using the studs for the original floor
New board in place. It all fits nicely
New carpet stuck to the board with contact adhesive
Stuck some anti-rattle felt on the LPG tank support braces so it doesn't squeak
All stuck together
In place and held down with the tie-down loops, and with D2 fuel-line screws going through the board on to the original studs.
Made a little handle to lift the floor up. The original plastic handle won't fit because of the tank, but since there's no spare wheel and the tyres are run-flats, I can't see much need to go under here!
Finished
Its black rather than dark grey since I've never been able to find aftermarket carpet that matches the D2 boot, but it beats no floor at all!
ID:	18626   Click image for larger version
ID:	18627   Click image for larger version
ID:	18628   Click image for larger version
ID:	18629   Click image for larger version
ID:	18630   Click image for larger version
ID:	18631   Click image for larger version
ID:	18632   Click image for larger version
ID:	18633   Click image for larger version
ID:	18634   Click image for larger version
ID:	18636   Click image for larger version
ID:	18637   Click image for larger version
ID:	18638   Click image for larger version
ID:	18639   Click image for larger version
