Old 4th November 2018, 06:11 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Originally Posted by awolfinsheepsclothes View Post
I wasn't even aware of the master cylinder flex problem.
Dave
Nor me!
I've watched some of the commercial scale 3D printers that wiggle/chain reaction cycles use for prototyping new parts.
Their machine could knock out the fog light grilles in a couple of hours
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 4th November 2018, 09:59 PM
Just discovered that contrary to expectation, my mk2 doesn't clear the plastic trim so more fiddling needed there.
Thought it looked like a tight fit, hence the question....
Given the way it fits round the strut brace and the primary direction of force the top appears largely superfluous so could be reduced?
Maybe even become a clip-on item again?
Old 6th November 2018, 03:28 AM
27litres's Avatar
27litres 27litres is offline
When you've sorted the prototyping of the master cylinder wedge, I'll take two in carbon filament please MJ!
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 18th November 2018, 06:36 PM
I've been making parts for the manual swap so I thought I'd show how to go from concept to physical part.
The original footrest has to change to make room for the clutch pedal, and rather than mucking around with the original I thought I'd just print a new one.
I started by tracing the outline of one edge of the original footrest on to a piece of A4, and then scanned it in as a tiff image:
Next, I used an online service to convert the tiff image from a bitmap to a DXF vector drawing. This is effectively a point cloud so not that useful yet.
I made the DXF in to a background layer in Autocad and then drew the shape over the top of it. This time its a nice CAD drawing using lines and arcs.
I imported the drawing in to Fusion360 and extruded it. Now we're getting somewhere
After a few hours of measuring the original and making some changes as I went along I got to this
Added the final detail and the 3D model is done
This would actually fit on my printer in one piece, but because of the angles it would need a lot of support structure. That takes a long time to print, and also adds a lot of risk as the support is very weak and its easy for the print head to knock it over resulting in a failed print. To avoid that, I cut it in half
Loaded the first half in to Cura for slicing. 20 hours to print...
First print done
Second print done
Glued together and next to the original
Installed. I'm pretty pleased with how it turned out, although I'll make some changes to the next one to speed up printing and improve strength.
ID:	20457   Click image for larger version
ID:	20458   Click image for larger version
ID:	20459   Click image for larger version
ID:	20460   Click image for larger version
ID:	20461   Click image for larger version
ID:	20462   Click image for larger version
ID:	20463   Click image for larger version
ID:	20464   Click image for larger version
ID:	20465   Click image for larger version
ID:	20467   Click image for larger version
ID:	20468   Click image for larger version
ID:	20469   Click image for larger version
Old 18th November 2018, 06:56 PM
You make it all sound so easy. I'm amazed at how you got from that first sketch to the extruded and 'some changes' later version.
Old 18th November 2018, 08:16 PM
It was about four hours from the extrusion to the first model, then another hour to add the final detail and cut it in half.
Old 18th November 2018, 08:35 PM
I didn't understand a word of that! are you sure it is english? and I've spent a couple of hours on sketchup, and Tinkered and watched hours of tutorials on youtube trying to get myself unto speed to buy a printer.
great work as usual MJ.
Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
Old 18th November 2018, 08:40 PM
It is English . . .well sort of geek.
I have purchased the same model as MJ and it is a cracking bit of gear and so much cheaper than these things were a few years back.
I'm OK on the theory but I am lucky in that my 36 year old son is also dead keen. He is playing on Autocad at the moment designing something for my model tramway. Just hoping that it all comes together.
Old 19th November 2018, 09:34 AM
I still don’t understand but I like it! good job you put plenty of pictures up! You went from a curve extruded too a masterpiece! Amazing I’ve done the tutorials and and that was fine so I went onto drawing what I wanted to make and nothing I had learnt applied to what I wanted to draw with double curvatures.
Respect!
Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1976 Reliant Kitten
1965 Porsche 911
Old 26th November 2018, 02:07 PM
Depending on what version of AutoCad you're using you can import PDF's straight in and scale them to suit
