Old 4th April 2020, 12:38 PM
Originally Posted by J i m s t e r View Post
The problem is everything is component-protected on an optical link, IIRC.
Since it's only the speakers being replaced, there shouldn't be an issue with component protection.
NightOwl - What about contacting the forum sponsors and asking them about speaker dimensions, as at least they are more likely to have them sitting around? You could also query impedance values as well.
Old 4th April 2020, 04:55 PM
NightOwl NightOwl is offline
Good idea, inquiry sent.
2006 Audi A8 3.0 TDI Quattro Sport
A8 W12/S8 Brakes front and rear (385mm/335mm)
Focal and JBL speakers, Helix amps
S8 anti-roll bars front and rear
Complete rear LED taillight
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
Old 6th April 2020, 12:28 PM
Short update.
I ripped off a door panel in the front today, and can say that no 3. party speakers will fit without considerable fabrication as the bracket for the speaker was molded together with the speaker housing. But that said, looking at the BOSE speakers for sale at eBay for the D3, it looks like the bracket is also molded together with the speaker housing in the same way, so maybe it would be just to swap them out?
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
Old 6th April 2020, 01:37 PM
It looks like an ordinary speaker screwed in to a bespoke bracket from pictures on Google images. Did you remove the speaker from the door card or just look at the back of it?
It also looks like Audison do a direct drop-in replacement: https://srotas24.co.uk/car-parts/aud...872993648.html
Old 6th April 2020, 06:03 PM
Thanks for the link and comment, MikkiJayne.
I removed the speaker completely from the door, and the bracket and the speaker housing is made out of one piece of plastic. Although, looking closer at the BOSE speakers, it looks like they are screwed into at separate bracket like those in the Audison link.
In the afternoon I received a message from Prestige Motor, that the BOSE speaker will fit directly and will work. He confirmed that they have done it for a customer. Obviously it won't be like a complete BOSE system without the proper amplifier and also the BOSE system has to two speakers in the parcel shelf (and a center treble in the front) that the std sound system doesn't have.
I feel tempted to go on with this...
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
Old 14th April 2020, 04:30 PM
dangerdred dangerdred is offline
Not meaning to send the thread OT but does anyone know why the standard door speakers have two input connections and the sound is the same from each?
Phantom Black 2008 A8 3.0 TDI SE ASB
Old 15th April 2020, 07:11 PM
Good question! My initial thought was that Audi used the same speaker in more models and may have two together and use the second connection to connect the other speaker. It would lower the impedance and the amp wouldn't be too happy with that though. Also, doing a search on 4E0035411M, gives only A8 D3 fitment, so maybe it's not used in any other models? On the other hand, a lot of speaker elements do have dual terminals for plus and minus.
Talking about speakers, the BOSE set is on the way and have expected arrival on Friday.
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
