Old 15th April 2020, 09:25 PM
It shoes as N/S/R speed sensor intermittent signal but having read some threads I'm not sure if it actually is this or something else? ... Also, anyone know the OEM or should I just buy from TPS?
N/S is the left side, correct? If so, part number is 4E0927803D, superseded with F. O/S (right, in case I've got my sides wrong) is 4E0927804D, superseded with F.
Old 16th April 2020, 07:03 AM
NightOwl NightOwl is offline
What does the ABS fault say? Does the ABS work properly?
2006 Audi A8 3.0 TDI Quattro Sport
A8 W12/S8 Brakes front and rear (385mm/335mm)
Focal and JBL speakers, Helix amps
S8 anti-roll bars front and rear
Complete rear LED taillight
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
Old 16th April 2020, 08:31 AM
homer simpson's Avatar
I'll rescan it today and post a log. Not sure how I can test the ABS
Old 16th April 2020, 04:20 PM
Without traffic around, brake hard and see/hear/feel if any wheel locks or not. If you are used to braking hard until the ABS gets activated, does it feel and behave the same way now? Be careful though.
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
Old 16th April 2020, 04:35 PM
OK it has now thrown a hissy fit! I went to read the codes and see what is showing.
Firstly, the car doesn't have a N/S/R speed sensor, from what I gathered it's front left and rear right. I checked the N/S/R wheel and can't see one either.
With VCDS I tried to see what the ABS module is showing and it can't communicate with it now...and this has thrown up lots of faults. Parking brake, ABS and ESP were already there but now also headlamp, jacking light is on, level sensor, etc etc. My guess is that the ABS module is faulty and the car cannot determine lots of other data because of this and so it is throwing faults. These modules just show as DTC not supported or cannot read (or something to that effect).
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000731
Shop #: WSC 12982 000 1048576
VCID: 2019E2C9F6C1A42B732-8074
3 Faults Found:
01316 - ABS Control Module
008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Fault Frequency: 23
Reset counter: 26
Mileage: 158728 km
Time Indication: 0
Date: 2020.04.15
Time: 14:33:38
Freeze Frame:
Voltage: 10.04 V
Count: 231
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 9
Mileage: 133232 km
Time Indication: 0
Date: 2015.09.24
Time: 00:02:20
Freeze Frame:
Voltage: 10.46 V
Count: 61
01312 - Powertrain Data Bus
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 66
Mileage: 158728 km
Time Indication: 0
Date: 2020.04.16
Time: 16:08:20
Freeze Frame:
Voltage: 10.66 V
Count: 20
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 K HW: 4E0 614 517 BT
Component: ESP 5.7 allrad H49 0650
Coding: 0001927
Shop #: WSC 02313 000 00000
VCID: 2B0305E58F077773D60-807E
1 Fault Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
012 - Electrical Fault in Circuit
Gateway Installation List: 4L0 910 468 A
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
11-Engine II -- Status: Malfunction 0010
31-Engine other -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Old 16th April 2020, 06:32 PM
OK hissy fit over lol. I walked away and left it before I had a cardiac arrest! Went back to the car and all the other faults have disappeared again. Can communicate with all modules and it seems more and more like the ABS module is at fault. I am guessing the control module is part of the ABS pump? Can't find any with my part number, so I may have to remove it and send it away for repair if it is at fault. Here's the scan
Thursday,16,April,2020,18:25:51:09330
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.0.1 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WAUZZZ4E28N009544 License Plate: S8
Mileage: 158730km-98630mi Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 13 15 16 17 19 1D 1E 28
34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 65 67 6C 72 76
77
VIN: WAUZZZ4E28N009544 Mileage: 158730km-98630miles
03-ABS Brakes -- Status: Malfunction 1010
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 552 G HW: 4E0 907 552
Component: 5.2L V10/4V FSI ª0020
Revision: 5AH15--- Serial number: AUX3Z0H0339315
Coding: 01060003190F0260
Shop #: WSC 00191 264 15243
VCID: 2615F4D194E54A1B09E-8072
1 Fault Found:
049441 - No Communication with ABS Brake Control Module
U0121 - 008 - - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 158734 km
Time Indication: 0
Date: 2020.04.16
Time: 17:11:01
Freeze Frame:
RPM: 644 /min
Load: 20.0 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 45.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.462 V
Readiness: 0010 1001
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E2 910 156 C HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI RdW 0030
Revision: --H04--- Serial number: 0117917
Coding: 0000001
Shop #: WSC 02313 785 00200
VCID: 2411EED9E2D9B80B17A-8070
1 Fault Found:
049442 - No Communication with ESP (Vehicle Dynamics) Control Module
U0122 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 158734 km
Time Indication: 0
Date: 2020.04.16
Time: 17:15:58
Coding: 0001927
3 Faults Found:
00003 - Control Module
014 - Defective
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 A
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0H0339315
Coding: 0412672
VCID: 58E98A29EE112CEB4B2-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
No fault code found.
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300LY077590793
Coding: 0000002
VCID: 3A2D30A1705DDEFB5D6-806E
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000054257
Subsystem 3 - Serial number: 0115.12.070000000100010049ÿ
Subsystem 4 - Serial number: 010049ÿ
1 Fault Found:
01319 - Control Module for Distance Control (J428)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Mileage: 158734 km
Time Indication: 0
Date: 2020.04.16
Time: 17:22:20
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000139701
Coding: 0123001
VCID: 1C61D639DAA980CBAFA-8048
3 Faults Found:
00819 - High Pressure Sensor (G65)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 27
Mileage: 158734 km
Time Indication: 0
Date: 2020.04.16
Time: 17:19:10
00065 - Rear Left Footwell Heater (Z42)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 26
Mileage: 158734 km
Time Indication: 0
Date: 2020.04.16
Time: 17:00:46
Freeze Frame:
Voltage: 13.10 V
00066 - Rear Right Footwell Heater (Z43)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 26
Mileage: 158734 km
Time Indication: 0
Date: 2020.04.16
Time: 17:00:46
Freeze Frame:
Voltage: 13.30 V
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0133121
VCID: 38292AA94E51CCEBAB2-806C
Subsystem 1 - Part No: 4E2 910 113 C
Component: Wischer WWS D3 H60 0440
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00141886
Shop #: WSC 02313
Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785
Component: SG ext.Player H15 0850
Revision: 00000000
Coding: 010000
Shop #: WSC 02399 823 56573
VCID: 2B0305E583077773D60-807E
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276V8001047
Coding: 0000001
Address 11: Engine II Labels: Redir Fail!
2 Faults Found:
005491 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 158733 km
Time Indication: 0
Date: 2020.04.15
Time: 15:04:45
Freeze Frame:
RPM: 653 /min
Load: 20.4 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 48.0°C
Voltage: 12.827 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 158734 km
Time Indication: 0
Date: 2020.04.16
Time: 17:11:01
Freeze Frame:
RPM: 644 /min
Load: 20.0 %
Speed: 0.0 km/h
Temperature: 90.0°C
Temperature: 45.0°C
Voltage: 13.462 V
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 F HW: 4E0 907 561 F
Component: ABSTANDSREGELUNGH03 0020
Coding: 0041154
VCID: 2517F3DDE9E34103004-8070
3 Faults Found:
02213 - Function Disabled due to Brake Temperature
000 - - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10110000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 67
Mileage: 158732 km
Time Indication: 0
Date: 2020.04.16
Time: 17:10:00
Freeze Frame:
Temperature: 34.0°C
Voltage: 13.31 V
Bin. Bits: 00100010
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11111101
Fault Priority: 5
Fault Frequency: 5
Reset counter: 27
Mileage: 158732 km
Time Indication: 0
Date: 2020.04.16
Time: 17:11:00
Freeze Frame:
Temperature: 35.0°C
Voltage: 10.88 V
Bin. Bits: 00100010
01330 - Central Control Module for Central Convenience (J393)
013 - Check DTC Memory - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10111101
Fault Priority: 5
Fault Frequency: 2
Reset counter: 67
Mileage: 158732 km
Time Indication: 0
Date: 2020.04.16
Time: 17:12:00
Freeze Frame:
Temperature: 38.0°C
Voltage: 11.78 V
Bin. Bits: 00100000
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 E HW: 4E0 959 655 K
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CU0006XRP
Coding: 0431707
VCID: 2809FAE99EF15C6B3B2-807C
Subsystem 1 - Serial number: 63328RB40346E335G
Subsystem 2 - Serial number: 63428RB40346E32DO
Subsystem 3 - Serial number: 63528RB40346E2AFY
Subsystem 4 - Serial number: 63628RB40346E2DCZ
Subsystem 5 - Serial number: 63729RB4030C466BP
Subsystem 6 - Serial number: 63829RB4030C46B4O
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 67
Mileage: 158734 km
Time Indication: 0
Date: 2020.04.16
Time: 17:15:58
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 C
Component: J0527 0410
Revision: 00H05000 Serial number: 90026073280160
Coding: 0112151
Component: E0221 H02 0030
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 981 F HW: 4E0 920 981 F
Component: KOMBIINSTR. VDO H83 0620
Revision: D03 Serial number: AUDID3H0000486
Coding: 0048423
Shop #: WSC 53816 003 1048576
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4E0 907 468 H
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 0200J07B0981FB
Coding: F5F5DFFF717E1E00
VCID: 2D070BFDB1137943C84-8078
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 67
Mileage: 158734 km
Time Indication: 0
Date: 2020.04.16
Time: 17:15:58
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 A HW: 4E2 905 218 B
Component: FPI_1 H01 0020
Revision: 01000102 Serial number: 20112007223929
Shop #: WSC 00000 000 00000
VCID: 1F1BE135CBBF9BD34A8-804A
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046002 Serial number: AUZ5ZBG4064368
VCID: 1A6DD021D09DFEFBBD6-804E
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000020 Serial number: 00000000064774
Coding: 0000000
VCID: 619FA7CDBD4BED233CC-8034
Address 34: Level Control Labels: User\4E0-910-553.lbl
Part No SW: 4E0 910 553 L HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 6340
Coding: 0015510
VCID: 2C0106F98A09704BDFA-8078
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 67
Mileage: 158734 km
Time Indication: 0
Date: 2020.04.16
Time: 17:22:20
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4063342
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H51 1060
Revision: 00000000 Serial number: 364AY087746358
Shop #: WSC 00149 210 93595
VCID: 3B2335A57F67E7F3460-806E
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 67
Mileage: 158734 km
Time Indication: 0
Date: 2020.04.16
Time: 17:16:02
Freeze Frame:
Bin. Bits: 1100
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000729700113
Coding: 0232932
Shop #: WSC 00613 210 85940
VCID: 1D67DB3DC1B389C3584-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 F
Component: Türsteuer.FS BRM005 0180
Coding: 0032751
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H10 0030
Revision: 00300010 Serial number: W040712180219
Coding: 0004861
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 67
Mileage: 158734 km
Time Indication: 0
Date: 2020.04.16
Time: 17:11:01
Address 47: Sound System Labels: None
Part No SW: 4E0 910 466 D HW: 4E0 035 466
Component: BO_D3 H06 0320
Revision: 21S00002 Serial number: 00410070010684
Coding: 0000027
VCID: 270BF9D593EF5313328-8072
Subsystem 1 - Part No: 4E0 910 465 B
Component: BO_D3_SLAVE H31 0310
Subsystem 2 - Serial number: 01812070008204
Subsystem 3 - Serial number: 0218.12.070000000100030038ÿ
Subsystem 4 - Serial number: 030038ÿ
1 Fault Found:
03016 - Motor for Front Right Treble Speaker (V345)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 5
Fault Frequency: 3
Reset counter: 68
Mileage: 158734 km
Time Indication: 0
Date: 2020.04.16
Time: 17:22:20
Freeze Frame:
Voltage: 11.90 V
Temperature: 47.0°C
Bin. Bits: 00000100
Voltage: 12.00 V
Temperature: 50.0°C
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 B
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000009691
Coding: 0010111
VCID: 1E65DC31CCB592DB41E-804A
Subsystem 1 - Part No: 8K0 907 410
Component: EHL205.06.02KHT H02 0010
Subsystem 2 - Serial number: 1451557T04Z601
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 67
Mileage: 158732 km
Time Indication: 0
Date: 2020.04.16
Time: 17:15:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 F
Component: Türsteuer.BF BRM005 0180
Coding: 0032751
Revision: --H03---
Coding: 0000731
4 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 9
Mileage: 133232 km
Time Indication: 0
Date: 2015.09.24
Time: 00:02:20
Freeze Frame:
Voltage: 10.46 V
Count: 61
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 27
Mileage: 158728 km
Time Indication: 0
Date: 2020.04.16
Time: 18:08:04
Freeze Frame:
Voltage: 10.25 V
Count: 231
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 67
Mileage: 158728 km
Time Indication: 0
Date: 2020.04.16
Time: 17:38:33
Freeze Frame:
Voltage: 11.08 V
Count: 20
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 67
Mileage: 158728 km
Time Indication: 0
Date: 2020.04.16
Time: 17:11:02
Freeze Frame:
Voltage: 12.73 V
Count: 242
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000018
VCID: 290FFFED85FB656324C-807C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 40
Mileage: 158728 km
Time Indication: 0
Date: 2020.04.16
Time: 17:16:00
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396A 087587354
Coding: 0000001
VCID: 313F178DAD2B1DA3ECC-8064
Address 57: TV Tuner Labels: None
Part No SW: 4E0 910 148 E HW: 4E0 919 148
Component: R78 TVHybridDVB 0470
Revision: R0H06000 Serial number: 76300801113601
Coding: 0000003
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000019927
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2712210239
Coding: 344530393135313035412056413032373132323130323339
Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032751
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000900055800
Coding: 0252329
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H46 0630
Revision: 00000000 Serial number: 00000712180174
Shop #: WSC 12336 024 394758
VCID: 3635249144453A9BB9E-8062
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J7Z100T
Coding: 1021302
VCID: 5CE196399A29C0CB6FA-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032751
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08740734903481
Coding: 0321008
VCID: 2313EDC5E7D7BF336E0-8076
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 67
Mileage: 158734 km
Time Indication: 0
Date: 2020.04.16
Time: 17:15:57
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 C HW: 4F1 862 335
Component: BTA H10 0960
Revision: 00H10000 Serial number: 00000007554357
Coding: 0060001
End----------(Elapsed Time: 02:36, VBatt start/end: 12.8V/13.4V)-----------
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
34-Level Control -- Status: OK 0000
37-Navigation -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Old 16th April 2020, 07:37 PM
I'm not any car electronic wizard, but I replaced the battery in my car about a month ago, and it gave "millions" of faults when starting the car afterwards and the dash lit up like a Christmas tree. I was able to clear most of them with VCDS, but I think it was the ESP symbol that was still on after several attempts to clear the faults. The ESP symbol went out after driving a few hundred meters (and maybe I also touched the brake pedal a bit).
As your car has been without power and then being charged, I would try to disconnect the battery for a few minutes and then connect and see what happened. And by the way, was the charger connected the recommended way?
Xenon fog lights
All interior LED
S8 rims 9x20"
Stage II tune
S8 Grill
That's correct and yes the part numbers are the same as what I found on ETKA so thanks for the clarification. There is a new/old stock on ebay which I might purchase as it's cheap. Firstly though, I will get the old sensor off and give it a clean incase there is some dirt ingress due to it standing.
