  #30
Old 9th November 2020, 09:50 AM
The implication there is that, assuming the pump is seated correctly, that the long bolt simply isn't tight enough and thus isn't compressing the D-shaped gasket and allowing air in to the pump. That would suggest some sort of lubricant is needed on the bolt thread which is compatible with petrol but which doesn't dissolve in petrol.
