Old 16th November 2010, 08:30 AM
That basically means one of the sensors is duff. Vagcom can tell you which one... You can reset the fault, and it will maybe work again, breifly, but really it will need a new one... Its not uncommon unfortunately.....
In this weather there is small chance that grit and crud from the road can coat them and cause duff readings, a good clean might afford you a little more time with it...
Sensors are only about £50 i think, and its not too hard to fit them...
