Old 21st May 2021, 09:34 PM
Markiii Markiii is offline
Looking good MJ
Be so much easier to get the new O2 sensors in with those manifolds out of the car
Old 22nd May 2021, 04:13 PM
I love these posts Michaela
Old 22nd May 2021, 05:01 PM
There's a level of thought, understanding, creativity and engineering "sympathy" evident that you will never ever find at a dealer and probably not even the very best independent specialist.
Old 24th May 2021, 09:30 PM
A slightly frustrating weekend as the timing belt still hadn't turned up so there was a limited amount I could do.
Flipped the engine back over once the sump sealant was dry
As usual the temperature sensor was rusted in place, so had to be destroyed to get it out.
Pretty crusty
Cleaned up ok
The coolant pipe o-rings were also pretty crusty
Replacement link hose and powdercoated coolant pipe
No amount of elbow grease would clean up the manifold, and I had nothing else to do so I gave it a lick of matt silver paint
Sunday morning after the paint has dried. New inlet manifold gaskets on, ready for the manifold
Manifold refitted
Crank oil seal - this was dried up and leaking
New seal fitted to the bushing
and pushed in place with the purpose-made tool. The manual says to push the seal in place and then fit the bushing, but that is extremely difficult to do without folding over the lip of the seal, hence why I fit the bushing to the seal off the engine so I can make sure its all ok, before fitting both bits together.
Old crank pulley bolt at the top, new one at the bottom. It has stretched about 2mm!
Stuck now with no timing belt or thermostat
Monday - SAI blanks fitted and new manifold bolts
The belt kit finally arrived, drop shipped from Poland because there is almost no stock left in the UK No thermostat yet because somehow I forgot to order it That'll be here tomorrow though and then the engine will be almost finished, bar the flywheel, belt covers and spark plugs which will all be done on the separating table.
Mark - this is one of the long nuts which goes through the manifold
ID:	26463   Click image for larger version
ID:	26464   Click image for larger version
ID:	26465   Click image for larger version
ID:	26466   Click image for larger version
ID:	26467   Click image for larger version
ID:	26468   Click image for larger version
ID:	26469   Click image for larger version
ID:	26470   Click image for larger version
ID:	26471   Click image for larger version
ID:	26473   Click image for larger version
ID:	26474   Click image for larger version
ID:	26475   Click image for larger version
ID:	26476   Click image for larger version
ID:	26477   Click image for larger version
ID:	26478   Click image for larger version
Old 25th May 2021, 08:43 AM
thanks MJ so that bolt, holds on the manifold?
ref
what am i looking at there? coolant pipe? green cable ties?
Old 25th May 2021, 08:50 AM
Hi MJ, why the secondary air injection delete? Is this a manual conversion?
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 25th May 2021, 08:16 PM
Yes. there are a dozen ordinary M8 flanged nuts, and then two of these long nuts which go right through holes in to the manifold.
Thermostat bypass pipe with the bank1 knock sensor cable tied to it, per the factory installation, although the factory used black ties. You get green since I ran out of black There is a satisfactory serendipity having the cable ties match the knock sensor connector, not that you're likely to ever see them again since they live under the inlet manifold.
Cos its a waste of space and weight and adds lots of pointless plumbing down the back of the engine which just gets in the way. It vexes me greatly and I like to apply the principle of 'reduce and simplify' whenever I can
Old 26th May 2021, 05:05 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
Have you been to Lidl by chance? My dad handed me a pack of green cable ties the other day...wondered where on earth I would use them?
If I had know that when rebuilding my S8 it would have saved a lot of swearing and bleeding knuckles!
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 26th May 2021, 07:43 AM
I actually use them for labelling waste oil barrels. Green means clean oil suitable for burning. Red means contaminated with water which must be taken for recycling
They're also used when I run out of black ones
Old 26th May 2021, 08:38 PM
Forgot I had to go to the office in Leeds yesterday (650 mile round-trip!) so I finished off the engine tonight instead.
New thermostat in place
The cover went on without fully removing the belt
Tensioned the belt and finished everything off
Spec here is 5mm +/- 1mm.
New fan bearing and tensioner roller also in place
Engine back on the separating table
The starter teeth on the original flex plate were pretty trashed after eating bits of starter motor so I replaced it with a good spare, and thats the major engine work complete. All that's left is to put the spark plugs back in and coil packs on once I've spun it on the starter to get oil pressure, and then the replacement wiring harness and coolant hoses go back on when it's reattached to the gearbox.
Gearbox on the stand for its service. As this is in very good condition and not leaking I'm leaving all the output flanges alone and just doing the filter and ATF which is a job for tomorrow
ID:	26483   Click image for larger version
ID:	26484   Click image for larger version
ID:	26485   Click image for larger version
ID:	26486   Click image for larger version
ID:	26487   Click image for larger version
ID:	26488   Click image for larger version
ID:	26489   Click image for larger version
