Let us know what happens when you get the jumper plugs inserted. That might allow the MMI and radio to work properly, assuming that one of the other modules is causing a problem. Once you get the MMI sorted, you should be able to change the date/time.
Got time with the car today
Connected the jumper and found it is the amplifier which is faulty Managed to change date and time as you say Any one repair the amplifier 4E0910223C Will have a look inside incase it's a dry joint as it has switched on a few times and worked while driving
Audi A8 d3 4.2 petrol 2004 Blue |
I can only find one company online that repair Bose amps, but only from year '06 onwards. You could always email them to confirm, just in the off chance that they could do it: https://boserepairexperts.co.uk/
Thanks for your help steamship
I will let you know what I find when I open it tomorrow Hope fully a dry joint or dead capacitor One problem I do have is heavy steering Very strange Car does have adjustment on the column But not working I did clear the error but it comes back instantly
What's the error code you're getting for the steering?
Unsure what I have done
Changed the amplifier and it worked for a couple of mins then shut down Sunday,04,December,2022,12:16:04:08597 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4 Data version: 20221026 DS344.0 www.Ross-Tech.com -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Control Module Part Number: 4E0 910 468 Component and/or Version: Gateway H07 0070 Optical Bus Diagnostic : 3dB Attenuation Controller Electrical Optical 19-CAN Gateway OK OK 07-Control Head(High/D3) OK OK 0E-Media Player 1 ERROR ERROR 1E-Media Player 2 OK OK 47-Sound System ERROR ERROR 56-Radio OK ERROR 57-TV Tuner OK OK 37-Navigation OK ERROR 0F-Digital Radio ERROR ERROR ************************************************** ********** Saturday,10,December,2022,11:24:47:08597 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 22.10.0.1 (x64) HEX-V2 CB: 0.4623.4 Data version: 20221026 DS344.0 www.Ross-Tech.com VIN: WAUZZZ4E84N015326 License Plate: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 0E 0F 13 15 16 17 19 1E 1F 25 2E 34 36 37 38 3E 42 46 47 4E 4F 52 53 56 57 5E 61 62 65 72 76 VIN: WAUZZZ4E84N015326 Mileage: 116120km-72153miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: Cannot be reached 1100 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: Cannot be reached 1100 0F-Digital Radio -- Status: Cannot be reached 1100 13-Auto Dist. Reg -- Status: Cannot be reached 1100 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: Cannot be reached 1100 1F-Sat. Tuner -- Status: Cannot be reached 1100 25-Immobilizer -- Status: OK 0000 2E-Media Player 3 -- Status: Cannot be reached 1100 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: Cannot be reached 1100 38-Roof Electronics -- Status: OK 0000 3E-Media Player 4 -- Status: Cannot be reached 1100 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Cannot be reached 1100 4E-Ctrl Head RR -- Status: Cannot be reached 1100 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 56-Radio -- Status: Cannot be reached 1100 57-TV Tuner -- Status: Cannot be reached 1100 5E-Ctrl Head LR -- Status: Cannot be reached 1100 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: Malfunction 0010 72-Door, Rear Right -- Status: Malfunction 0010 76-Park Assist -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine Labels: 077-910-560-BFM.clb Part No SW: 4E0 910 560 Q HW: 4E0 907 560 Component: 4.2L V8/5V G 0030 Revision: 00000000 Serial number: AUX3Z0CN127976 Coding: 0011773 Shop #: WSC 00411 210 96661 VCID: 2F381B434B1F5523428-807A VINID: 9D196AAAA1152047800450C21865F1B97A 2 Faults Found: 17981 - Left Engine Mount Solenoid Valve (N144) P1573 - 004 - Open Circuit 17985 - Right Engine Mount Solenoid Valve (N145) P1577 - 004 - Open Circuit Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E0 910 156 E HW: 09E 927 156 A Component: AG6 09E 4,2L5V RdW 0110 Revision: 00000001 Serial number: 0025352 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 2412E46F12D9E67BAFA-8070 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 M Component: ESP 5.7 allrad H44 0500 Coding: 0008597 Shop #: WSC 02313 000 00000 VCID: 221EE27708CDE84BDD6-8076 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H03 0130 Revision: 01303703 Serial number: AUX3Z0CN127976 Coding: 0264192 Shop #: WSC 02311 785 00200 VCID: 58EA809F1E11729BF32-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory BFS H07 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 00000 785 00200 VCID: 2310E77317D7E143D60-8076 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Cannot be reached ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 HW: 4E0 820 043 A Component: KLIMAAUTOMAT 016 0240 Revision: 00000022 Serial number: 00000000030648 Coding: 1069057 Shop #: WSC 02311 785 00200 VCID: 5AEE9A97601D608BC56-800E 4 Faults Found: 01592 - Air Quality Sensor (G238) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 1 Reset counter: 207 Mileage: 116124 km Time Indication: 0 Date: 2022.12.10 Time: 11:19:47 Freeze Frame: Temperature: 20.0°C 00819 - High Pressure Sensor (G65) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 1 Reset counter: 195 Mileage: 115825 km Time Indication: 0 Date: 2003.04.03 Time: 23:18:10 01857 - Air Outlet Sensor; Middle Left (G347) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 38 Reset counter: 246 Mileage: 115826 km Time Indication: 0 Date: 2003.04.03 Time: 23:50:49 01858 - Air Outlet Sensor; Right Center (G348) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 20 Reset counter: 246 Mileage: 115826 km Time Indication: 0 Date: 2003.04.03 Time: 23:50:58 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.clb Part No SW: 4E0 910 279 E HW: 4E0 907 279 E Component: ILM Fahrer H11 0100 Coding: 0000001 Shop #: WSC 02311 785 00200 VCID: 2A0E0A5770FD300B956-807E Subsystem 1 - Part No: 4E2 910 113 Component: Wischer WWS D3 H30 0320 Coding: 00000030 Shop #: WSC 02311 1 Fault Found: 02510 - Steering Column Adjustment 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 3 Fault Frequency: 254 Reset counter: 78 Mileage: 22878 km Time Indication: 0 Date: 2009.05.01 Time: 09:37:15 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Cannot be reached ------------------------------------------------------------------------------- Address 0F: Digital Radio Cannot be reached ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg Cannot be reached ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 G Component: Airbag 8.4E+ H10 0940 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 6390A7735757A143960-8036 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H13 0040 Coding: 0112141 Shop #: WSC 02311 785 00200 VCID: 6594B96B5963DF73784-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H03 0070 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 900 HW: 4E0 920 950 CX Component: KOMBIINSTR. VDO H42 0070 Revision: D08 Serial number: AUDID3C6000184 Coding: 0016403 Shop #: WSC 00411 210 175099 VCID: 5CE29C8F6A299EBBD7A-8008 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4E0-910-468.clb Part No SW: 4E0 910 468 HW: 4E0 907 468 A Component: Gateway H07 0070 Revision: 07 Serial number: 1400303A0625E4 Coding: FEFE5BDDFBAD07 Shop #: WSC 00976 210 82602 VCID: 6594B96B5963DF73784-8030 9 Faults Found: 00384 - Optical Databus 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 5 Fault Frequency: 98 Reset counter: 207 Mileage: 115825 km Time Indication: 0 Date: 2003.04.03 Time: 23:30:10 02076 - Media Player Position 1 (R118) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 238 Mileage: 116010 km Time Indication: 0 Date: 2003.04.10 Time: 12:27:01 02078 - Media Player Position 3 (R120) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 238 Mileage: 116010 km Time Indication: 0 Date: 2003.04.10 Time: 12:27:01 02079 - Media Player Position 4 (R121) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 238 Mileage: 116010 km Time Indication: 0 Date: 2003.04.10 Time: 12:27:01 02230 - Digital Radio (DAB) (R147) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 238 Mileage: 116010 km Time Indication: 0 Date: 2003.04.10 Time: 12:27:01 02075 - Rear Right Information Display Control Head Control Module (J649) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 238 Mileage: 116010 km Time Indication: 0 Date: 2003.04.10 Time: 12:27:01 02074 - Rear Left Information Display Control Head Control Module (J648) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 238 Mileage: 116010 km Time Indication: 0 Date: 2003.04.10 Time: 12:27:01 02218 - Satellite Radio (R146) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 238 Mileage: 116010 km Time Indication: 0 Date: 2003.04.10 Time: 12:27:01 00463 - Control Module for Digital Sound Package (J525) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 238 Mileage: 116010 km Time Indication: 0 Date: 2003.04.10 Time: 12:27:01 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Cannot be reached ------------------------------------------------------------------------------- Address 1F: Sat. Tuner Cannot be reached ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 Component: FBS AUDID3 H03 0130 Revision: 01303703 Serial number: AUX3Z0CN127976 Coding: 0264192 Shop #: WSC 02311 785 00200 VCID: 58EA809F1E11729BF32-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 2E: Media Player 3 Cannot be reached ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.clb Part No SW: 4E0 910 553 E HW: 4E0 907 553 E Component: LUFTFDR.-CDC H05 4290 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 2514F96B19E31F73B84-8070 1 Fault Found: 01772 - Signal from Level Control Pressure Sensor (G291) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 26 Reset counter: 246 Mileage: 115826 km Time Indication: 0 Date: 2003.04.03 Time: 23:51:07 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory FS H07 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063330 Shop #: WSC 00000 785 00200 VCID: 2310E77317D7E143D60-8076 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Cannot be reached ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H01 0090 Serial number: 00000331300033 Coding: 0035840 Shop #: WSC 02313 785 00200 VCID: 1D64D18B31B3D7B3E04-8048 No fault code found. ------------------------------------------------------------------------------- Address 3E: Media Player 4 Cannot be reached ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 HW: 4E2 959 802 Component: Türsteuer.FS BRM005 0110 Coding: 0028450 Shop #: WSC 02311 785 00200 VCID: 5EE696877C358CABB9E-800A 1 Fault Found: 02111 - Motor for Window Regulator 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 3 Fault Frequency: 1 Reset counter: 199 Mileage: 116032 km Time Indication: 0 Date: 2022.12.06 Time: 07:34:42 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H03 0030 Revision: 00300003 Serial number: W040311180041 Coding: 0000217 Shop #: WSC 02311 785 00200 VCID: 2708F36363EF0D638A8-8072 Subsystem 1 - Part No: 4E0 907 719 Component: Neigungssensor H02 0020 2 Faults Found: 00892 - Switch for Trunk Closing Cylinder (F248) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 64 Reset counter: 238 Mileage: 115730 km Time Indication: 0 Date: 2003.04.01 Time: 04:35:15 01134 - Alarm Horn (H12) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 206 Mileage: 68437 km Time Indication: 0 Date: 2013.03.03 Time: 14:23:29 ------------------------------------------------------------------------------- Address 47: Sound System Cannot be reached ------------------------------------------------------------------------------- Address 4E: Ctrl Head RR Cannot be reached ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H08 0020 Revision: Serial number: 00000000027974 Coding: 0010101 Shop #: WSC 02311 785 00200 VCID: 1E66D6873CB5CCABF9E-804A 1 Fault Found: 01797 - Power Steering Hydraulic Pressure Valve (N119/N315) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 2 Fault Frequency: 69 Reset counter: 247 Mileage: 115664 km Time Indication: 0 Date: 2003.03.28 Time: 01:10:00 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 HW: 4E2 959 801 Component: Türsteuer.BF BRM005 0110 Coding: 0028450 Shop #: WSC 02311 785 00200 VCID: 5EE696877C358CABB9E-800A No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 HW: 4E0 907 801 Component: EPB A01H019 H01 0190 Coding: 0000531 Shop #: WSC 00022 210 75084 VCID: 5CE29C8F6A299EBBD7A-8008 1 Fault Found: 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01110000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 130 Time Indication: 0 Freeze Frame: Voltage: 12.01 V Count: 61 ------------------------------------------------------------------------------- Address 56: Radio Cannot be reached ------------------------------------------------------------------------------- Address 57: TV Tuner Cannot be reached ------------------------------------------------------------------------------- Address 5E: Ctrl Head LR Cannot be reached ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 A HW: 4E0 915 181 Component: ENERGIEMANAGER H02 0230 Revision: 00000000 Serial number: 00000005308435 Shop #: WSC 12345 128 00289 VCID: 1E66D6873CB5CCABF9E-804A Subsystem 1 - Part No: 000 915 105 SD Component: von TU3 1310310534 Coding: 303030393135313035534454553331333130333130353334 Shop #: WSC 12345 128 00289 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 801 A Component: Türsteuer.HL BRM005 0110 Coding: 0028450 Shop #: WSC 02311 785 00200 VCID: 5DE4918B713397B3A04-8008 No fault code found. ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.lbl Part No SW: 4E0 910 273 HW: 4E0 907 273 Component: Reifendruck 2 H01 0210 Coding: 0252127 Shop #: WSC 00000 785 00200 VCID: 5F98AB837B3F85A3B28-800A 2 Faults Found: 01477 - System Switched Off 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 4 Fault Frequency: 58 Reset counter: 236 Mileage: 115595 km Time Indication: 0 Date: 2003.03.21 Time: 03:57:08 Freeze Frame: Speed: 0.0 km/h Temperature: 11.0°C Error Code: 0 Not Recogn. Not Recogn. Not Recogn. Not Recogn. 01521 - Sensor for Tire Pressure 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 186 Mileage: 115601 km Time Indication: 0 Date: 2003.03.26 Time: 21:46:00 Freeze Frame: Speed: 9.0 km/h Temperature: 7.0°C Error Code: 0 Not Recogn. Not Recogn. Not Recogn. Not Recogn. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 HW: 4E0 959 802 A Component: Türsteuer.HR BRM005 0110 Coding: 0028450 Shop #: WSC 02311 785 00200 VCID: 5DE4918B713397B3A04-8008 2 Faults Found: 00470 - Company Comfort Databus in Single Wire 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 235 Mileage: 115824 km Time Indication: 0 Date: 2003.04.03 Time: 22:39:08 01482 - Motors for Central Locking 006 - Short to Plus - Intermittent Freeze Frame: Fault Status: 00100110 Fault Priority: 2 Fault Frequency: 2 Reset counter: 242 Mileage: 116048 km Time Indication: 0 Date: 2022.12.07 Time: 17:01:62 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 A HW: 4E0 919 283 B Component: Parkhilfe 8-Kan H11 0010 Revision: --.--.-- Serial number: 00000332500058 Coding: 0001008 Shop #: WSC 02313 785 00200 VCID: 211CED7B0DCBF353C4C-8074 1 Fault Found: 01628 - Sensor for Parking-Aid; Front Mid-Left (G254) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 187 Mileage: 115664 km Time Indication: 0 Date: 2003.03.28 Time: 01:10:19 End----(Elapsed Time: 01:53, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
1. The amplifier has component protection, so that needs removed before it will operate properly. I believe the symptoms you mentioned is what happens with CP active. This is of course assuming that when you say you 'changed' the amplifier, you put in another one. 2. When clearing the error codes, did you clear them one by one; i.e. going into each module and clearing them; or did you just select the 'clear all DTCs'? As good as VCDS is, one of it's downfalls is that the 'clear all DTCs' doesn't always do what it is supposed to. Using this latest scan, can you go into each module that has error codes and try and clear them, and note down which modules don't clear. Then just list the module numbers that still have errors. e.g. 01,46 etc (01 & 04 will definitely not clear). One final point. Is the TPMS warning light on in the instrument cluster?
No tpms error on the cluster
I did reset errors individually A few will not clear will get a look again
Had an issue with mmi in my old d3 and thought was water related. In th3 end it just needed a reboot….. units behind the glovebox, unplugged the cables and plugged em back in and all worked. May be worth a shot….
2021 Q7 4M, 3.0tfsi MHEV Black Edition 2002 D2 S8, Aqua Blue Pearl, original bar FE alloys and miltek 1997 D2 PF 4.2q, silver, Sport on roughly 90k and counting…. ** FOR SALE ** 1990 2.3 20v 7a Coupe Quattro **SOLD** 1996 2.6 v6 cabriolet, Isis red metallic **SOLD** 2014 D4, FL 3.0tdi, phantom black, sport exec lwb **DEAD ![]() Had a few Audis over the years, mostly early stuff, newest was a D3 prior to my D4, nothing much kept me smitten with other marques so I floated about a bit from one thing to another until that four ring lure caught hold |
Could not get radio or anything going
Then it would just come on and go off Got sick of trying And it stayed on for a few days Then went off again Eventually found out it was 30 amp fuse in the boot was arcing till it was black and no connection New fuse and connections cleaned works every time Next job is getting electric steering wheel adjustment to work and why the power steering is heavy but not massively heavy that you can't drive it
