Go Back   A8 Parts Forum > A8 D4 > D4 - Transmission
D4 - Transmission Gearboxes, diffs, drive shafts.
Old 1st April 2024, 08:54 AM
Saff Saff is offline
Default front drive shaft
Hi all, would anyone be able to tell me the part number for Front Drive Shaft ( OS but I'm sure they're not handed) please.
2010 D4 4.2tdi
Thanks in anticipation
Steve.
2010 D4 SE Executive 4.2 TDI
Old 1st April 2024, 11:12 AM
Thankfully they are not 'handed', but there are six different versions depending on engine spec. For a 4.2tdi, you should have a CDSB engine code.
If that is correct, the part numbers are either 4H0407271A or the later 4H0407271G.
Old 1st April 2024, 05:29 PM
Thanks Sean! CDSB is correct. I'm guessing either the A or G suffix would be compatable with my 2010 car or is that purely a revision to the part itself?
Steve
Old 1st April 2024, 06:11 PM
Yeah, A is the original, with G being a revision.
Old 1st April 2024, 06:57 PM
Thank you.
