Originally Posted by PsYcHe
Not sure about the FL LWB, but in the PF models, you can run cables through the bottom corner of the rear seatback panel (watch your hands, it's sharp in there), then along the bottom of the seat, and under the plastic covers at the top of the carpet (unless your cable is thick).
Thanks for that, did exactly that ,not too big a job only had to unclip the cover over the wheel and back seat cloth (it bends you don't have to take the changer out) and its all in, clipped the cable under the plastic trim.
Dissapointed that a) when on tv aux in, you cannot have max volume and b) bass, treble fader etc doesn't work. I guess this is a limitation of the TV input...
W
