Old 4th February 2012, 12:23 PM
Oli18's Avatar
Oli18 Oli18 is offline
Default D2 Front Rubber Winter Mats Part number
Hi all,
I was wondering if anyone has the RHD part numbers for the OEM front rubber winter floor mats by any chance? I know they have been discontinued by Audi but would still like the part numbers so i can do a bit of digging...
I know Audipages has them but they are for LHD.
If LHD are: 4D1 061 501B 041, should RHD be 4D1 061 501A 041?
Thanks,
Oli
Audi A8/S8 D2 Flickr Group
Old 4th February 2012, 12:39 PM
Looks plausible at 4D1 061 501A 041 : http://www.worldimpex.com/parts/genu...rub_74403.html
Old 4th February 2012, 01:58 PM
4D1 061 501A 041 is also for lhd, difference is a- for 98-00, b for 00-02.
RHD are 4D2 061 501 A for 98-00 and 4D2 061 501 B for 00-02
041 is not a actual part of part number but refers to color/material but since the above part numbers are only in black rubber 041 is not relevant
Old 4th February 2012, 03:19 PM
Oli18's Avatar
Thanks ainarssems!
...now just to find a set :S
Old 30th October 2012, 05:46 PM
Oli18's Avatar
After searching and searching with no luck, i gave up on OEM versions of these.
I chose to go down the aftermarket route to make sure the 8 is winter ready. These are custom fit. It came as a set of 4 including the rears ... overall, very pleased with a perfect fit including the clips!
Oli
Old 31st October 2012, 06:38 AM
Can you post alink please? They look pretty good
Old 31st October 2012, 07:33 AM
Now if you could get those in a silver-grey colour (aluminium effect) so they looked like those industrial plates that have the same pattern then it would be a really good look.
Old 31st October 2012, 10:47 AM
They do look good. Though the best mats I have had were OEM winter mats for a Volvo 740 which had a good 1'' upstand around them and could hold a pint or two of water and a fair amount of snow. No one else seems to do something similar.
