Old 9th June 2009, 06:08 PM
Yes, I did drive it the 11 miles to the air con specialist looking like that, I did reattach the bonnet though.
Getting degassed
Radiators off in this picture, its just leaning up against the car
On the weekend I rekon it will be treated to a full paintwork correction detail as a treat, expect to see this little monster at the next annual meet, complete with its new S8 front grill
ID:	308   Click image for larger version
ID:	309   Click image for larger version
Old 9th June 2009, 09:22 PM
Nice work Amar - and very quick thanks to A8 parts and a few local helpful businesses! Im impressed at how much progress u made - will bow down and hail you as I go past back down the M40 tomorrow!
Old 10th June 2009, 12:15 AM
LOL
Cheers for coming down and looking at her on Sunday, that bonnet really was jammed wasnt it!?
Old 10th June 2009, 06:02 AM
Going along nicely. Just in case you missed it in this picture
you can see that the engine needs a damn good detail and it's a great opportunity to do it!!
Old 10th June 2009, 07:40 AM
Oli18's Avatar
Oli18 Oli18 is offline
Nice one amar! This will be a great thread to follow!
Audi A8/S8 D2 Flickr Group
Old 10th June 2009, 10:40 AM
Thanks Oli, I'm a complete novice and have never done anything like this before so I hope it turns out a good thread and not a disastrious one.
Conan - Doing the engine is a little extreme for me, when the bonnet arrives, I will Duragloss it, clay it, menz IP it with a G220, then power gloss it and seal it with some Dodo
Old 10th June 2009, 10:45 AM
Quick question - about half a litre or so of ATF (guesstimate) came out when I took the ATF pipe out of the radiator. The car has just hit 70k miles (96 model, 4 speed box) and never had a fluid change. Should I get this done? Or should I just buy a litre from Audi and top up what came out?
Also while at Audi, is there a particular type of coolant that I should use? Will be doing the fluid change myself as I dont trust Audi to clean out all the sump magnets etc. and run it through the gears and refill if neccessary so labour charges ain't a problem.
Thanks in advance
Old 10th June 2009, 04:17 PM
Four speed boxes have rarely had any issues so I would just top up what you've lost.
The Coolant you need is G12++. To be sure it is pink in colour and if your existing coolant is not pink flush with fresh water, drain and replace with G12++.
Old 10th June 2009, 07:08 PM
Thanks Conan, exsisting coolant was pink. Where can I get some more G12++ from? Is this an Audi only part? Also how much will I need?
Old 10th June 2009, 07:59 PM
Thanks Conan, exsisting coolant was pink. Where can me.some more G12++ from? Is this an Audi only part? Also how much will I need?
I get mine from Audi and mix 50/50. You'll need about 3 ltrs of G12++ to make 6 ltrs. Make it 3 ltrs at a time.
