Old 11th June 2009, 10:16 AM
Got the ATF and G12++. Audi had it in stock. Just a quick question and it could be one that makes me look really stupid, but can you put ATF in back through the pipe it came out of. (The one that connects through the radiator).
Whilst I dont doubt you technically could squeeze it in there, the level at which you fill to is very precise and should be done from the correct fill location on the bottom of the pan. You just need to follow the famous audipages guide :
http://www.audipages.com/Tech_Articl...servicing.html
Just follow the bit at the end about refilling the fluid....
