  #30
Old 13th June 2009, 07:20 PM
I think the exact miles is 69k on the car, it's just it doesn't sound to healthy, cambelts never Been done so might aswell do that and the waterpump.
Audi do recommend them doing every 7 years, which is probably not unreasonable given that they are rubber and prone to perish...
Make sure you get a bloody good torque wrench and bar setup to (a) undo and (b) redo the crank shaft bolt. 280nm from memory - This working loose was the cause I believe of Mikes original engine getting well and truely goosed, so take no chances - Make sure its tight
