Old 22nd February 2013, 06:54 AM
RanjS8 RanjS8 is offline
Default Alignment
Anyone with a hunter machine should be good....also check on alignmycar.com.....be warned can still be hit n miss....1 place I went to were excellent but it closed down....the second place had the machine but didn't do camber adjustments....so confirm whether or not they do that first and the relative cost.
You should only need to realign the front though if u are only touch the front suspension
