Old 1st April 2013, 11:48 PM
kal_ay's Avatar
kal_ay kal_ay is offline
Think it is Mauritius blue,beautiful mate well done
2002 D2 S8 Misano Red
1996 Volvo 850R Estate Red
2013 Mercedes C63 AMG (taxi)
1991 Lotus Carlton Imperial Green
Old 2nd April 2013, 05:37 AM
Oli18's Avatar
Oli18 Oli18 is offline
Beautiful Ian. Looks like you got a great find!
...and so clean too!
Audi A8/S8 D2 Flickr Group
Old 2nd April 2013, 07:41 AM
And a nice clean PF S8 in the background. I see you've kept the clear side indicators, not reverted to original yellow (yet?).
Old 2nd April 2013, 08:29 AM
*had* to clean it. Been using it as my daily for 2 weeks, and still using it as my daily as I cant tax the new D3 yet
It was 'winter salt' white with a hint of underlying grey, so thought I'd best give it run over with some cleaning equipment...
My only dislike about the lighting at the moment is the non oem blue bulbs up front, but not bothered enough to spend 10 mins changing them
Old 2nd April 2013, 08:38 AM
Do you mean the main beams?
I had one fail; and bought some (many years ago now) that were whiter/brighter to try to better match the Xenon's and was reasonably happy with that.
Since then bulb technology has improved so you'd probably have a wider choice and get something brighter too as they're a bit feeble.
Not sure on 10 minutes though, you need to take the ballasts off the back and probably remove the air filter box in its entirety too to get at the things.
The guy I bought it from set the lights up very non-standard, which I reverted. He had realigned the Xenons upwards (a lot) to act as a main beam and used the foglights (which not everyone will know are in the main cluster) as his dipped beams.
Old 2nd April 2013, 09:16 AM
The 'tan' leather always looks worse in pics, but it's nice in the flesh.
You need to get the start button upgrade installed... The big round silver one does look a whole load nicer than the plain black square one.
Old 2nd April 2013, 09:31 AM
Its fingerprint... no can do...
Old 2nd April 2013, 10:33 AM
Just realised, you probably meant the indicators, which I'd forgotten were a bit naff.
I confess to having bought some allegedly "chromed" indicator bulbs rather cheaply that were actually not a great look having a blue-ish surface so I didn't use them straight away.
But when a bulb failed I fitted them both anyway. Getting some better-looking ones was then put on the "round tuit" list...
Mind you, 10 minutes to swap those is generous, provided you can get your fingers in to release the rather oddly-shaped indicator unit retaining catch.
Old 2nd April 2013, 10:44 AM
A bit?...
Yes, they are the ones that bug me....
