Old 11th October 2013, 03:00 PM
richardracer richardracer is offline
Default CPS repair
Hi Ian,
I had a CPS fault on my S8 and took it to the stealers for a warranty repair. Had a CEL and VCDS copied in below. Took a while with warranty company and some parts were not in stock so took it away for a few days and drove it after confirming it wouldn't harm engine.. Definite lowering of performance and a woofly sound rather than a wail from engine. Then blow me, the CEL went out by itself. Chat on one of teh US fourums suggested dirt in the oil which got stuck in the variable valve timing filter. I still had stealer change it as a precaution. However, before you commit check out parts prices
CPS - £69
Gasket (cam cover one) - £153!!
Coupling - £2
Labour 3 hours - £246. With VAT nearly £500!
Good luck
Richardracer
005416 - Camshaft Timing Adj. Bank1 (N205)
P1528 - 004 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 22
Mileage: 152030 km
Time Indication: 0
Date: 2013.05.25
Time: 13:59:57
Freeze Frame:
RPM: 920 /min
Load: 25.5 %
Speed: 6.0 km/h
Temperature: 103.0°C
Temperature: 62.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.589 V
2006 Audi S8 V10 Now Sold. Akoya Silver with black/grey leather, standard 20" wheels, hybrid TV, Bang & Olufssen audio, Heated seats front and rear, Dension ipod integration, DAB radio, keyless entry, rear electric blind, bluetooth connection to Apple iphone6S. Started at 60,000 miles end April 12. Now 171,500 miles as at Oct 2017. Now sold to fellow forum member.
