Old 11th December 2013, 07:36 PM
the first fault log is as you say populated with false alarms due to battery problems, the second log i'm guessing is a cut and paste from the original?
as the headers show faults but the later only shows two faults, which should be easily fixed.
my car was the same when i first got it as the battery was low.
you would be better driving it for a few days then re scan it
Old 11th December 2013, 09:50 PM
I'd see what you get after a couple of days driving about..
Old 30th December 2013, 08:00 PM
mannyo mannyo is offline
Well its been a few weeks since I got the D3, and I had to disconnect the battery again today to get underneath it to retrieve the missing captive nut.
I reconnected the battery, cleared all the codes and then did another auto scan.
The HVAC fault and the two door switch faults clear, but then come back again on another scan almost straight away.
The alarm fault, I am aware is most likely caused by siren failure.
So, looking for advice going forward on how to deal with these.
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H03 0120
Revision: 01203603 Serial number: AUX3Z0C8322740
Coding: 0411648
Shop #: WSC 02311 785 00200
VCID: D8BB0C531283
Part No: XXXXXXXXXXX
Component: ELV XXXX
2 Faults Found:
00190 - Driver's Door Handle Touch Sensor (G415)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 0
Reset counter: 24
Mileage: 207872 km
Time Indication: 0
Date: 2013.12.30
Time: 20:13:44
00191 - Passenger's Door Handle Touch Sensor (G416)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 24
Mileage: 207872 km
Time Indication: 0
Date: 2013.12.30
Time: 20:13:44
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043
Component: KLIMAAUTOMAT 016 0240
Revision: 00000020 Serial number: 00000000024718
Coding: 1069297
VCID: DABF165B6C8F
1 Fault Found:
00065 - Left Rear Footwell Heater (Z42)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 24
Mileage: 207885 km
Time Indication: 0
Date: 2013.12.30
Time: 20:09:47
Freeze Frame:
Voltage: 11.50 V
Manny
Past
Old 30th December 2013, 10:11 PM
Well I'm not one to believe in coincidence but it's the same fault with my drivers door handle, needs to be replaced as far as I know not fixable, the rear footwell heater on mines also playing up but it's a short to ground.
In your case I would check wiring is not been disturbed as there is no comms
Old 31st December 2013, 06:40 AM
I suspect your right with the footwell heater, perhaps something was disturbed with the wiring when the car was cleaned (badly I might add) by the dealer. I have no idea where the heater wiring is though, I guess its under the passenger seat somewhere or hidden under carpet?.
Both door handles appear to work fine, and I can unlock and lock the car using either side. What concerns me, is that perhaps these two faults are keeping the kessy module alive so that the car does not go to sleep and thus could lead to a flat battery eventually. Most of the time I only use the car for short trips, my old D2 only did 4500 miles in 12 months on UK roads.
Manny
Past
Old 31st December 2013, 07:05 AM
Not sure about the kessy module being kept alive but in regards to the door handle mine manifests itself by not unlocking the car when i place my fingers under the handle (proximity) and will only unlock by pulling up on the handle, then a second pull opens the car.
I have attached some files for your reading pleasure.
Old 31st December 2013, 02:20 PM
Oli18's Avatar
Oli18 Oli18 is offline
My driver's door is the same although it does work properly about 20% of the time.
Given the amount of driver door handles sensors that seem to be going faulty i wonder what the cause is...must be something consistently faulty that causes the same issue
Oli
Audi A8/S8 D2 Flickr Group
