Old 30th December 2013, 08:00 PM
Well its been a few weeks since I got the D3, and I had to disconnect the battery again today to get underneath it to retrieve the missing captive nut.
I reconnected the battery, cleared all the codes and then did another auto scan.
The HVAC fault and the two door switch faults clear, but then come back again on another scan almost straight away.
The alarm fault, I am aware is most likely caused by siren failure.
So, looking for advice going forward on how to deal with these.
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H03 0120
Revision: 01203603 Serial number: AUX3Z0C8322740
Coding: 0411648
Shop #: WSC 02311 785 00200
VCID: D8BB0C531283
Part No: XXXXXXXXXXX
Component: ELV XXXX
2 Faults Found:
00190 - Driver's Door Handle Touch Sensor (G415)
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 0
Reset counter: 24
Mileage: 207872 km
Time Indication: 0
Date: 2013.12.30
Time: 20:13:44
00191 - Passenger's Door Handle Touch Sensor (G416)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 24
Mileage: 207872 km
Time Indication: 0
Date: 2013.12.30
Time: 20:13:44
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043
Component: KLIMAAUTOMAT 016 0240
Revision: 00000020 Serial number: 00000000024718
Coding: 1069297
VCID: DABF165B6C8F
1 Fault Found:
00065 - Left Rear Footwell Heater (Z42)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 24
Mileage: 207885 km
Time Indication: 0
Date: 2013.12.30
Time: 20:09:47
Freeze Frame:
Voltage: 11.50 V
