Originally Posted by Goran
I also did this job with a trolley jack. Also found it annoying I could not fit a stand under the car when jacked up.
Thread hijack alert.
Has anyone any advice if it's possible to get stands in and where?
I jacked the car over the weekend but had to have it half in/out of workshop so I could position the jacking pad over the dip at the doorway. I simply lifted it using the trolley jack, is there a good spot to put axle stands (be kind I've just bought the A8) has anyone managed to get a low profile trolley jack that will go low enough to slide in? My current one is milimetres away from being usable, I'm considering simply carressing it with the angle grinder (the trolley jack not the car
