Old 15th December 2014, 08:28 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Nice one.
I need to do that retrofit at some point.
[center]
06 3.0TDI Quattro:
Options:
Old 15th December 2014, 12:44 PM
Oli18's Avatar
Oli18 Oli18 is offline
Thanks guys - really useful!
Don't suppose you have an actual ETKA illustration of the heater and the glow plug location and part number?
Many thanks,
Oliver
* Edit...is this it? and what number would be the glow plug:
Audi A8/S8 D2 Flickr Group
Old 15th December 2014, 09:26 PM
Have you tried unblocking it and clearing the codes?
You have to adapt the value of "1" to a value in adaptation channel 7
http://wiki.ross-tech.com/wiki/index.php/02251
It may just be a one-off fluke.
Also what about trying an injector cleaner additive in the fuel?
Good luck, looks a pig of a job really.
Old 21st December 2014, 08:05 PM
Burnzybubbles's Avatar
Just food for thought for you guys but on my e39 I fitted a 12v gsm relay unit in the car and used that to operate the webasto heater, all pin 1 needs is a constant 12v supply to keep it active, the telestart is good as I previously fitted one to the e39 but the gsm unit allows you to turn the heater on from anywhere with phone signal, telestart can only work within a certain range and walls/buildings reduce this range, I used to just txt the car and it'd turn the webasto on
