Old 31st October 2014, 10:17 AM
Can you actually get new tips and whats the cost ?? OEM ones of course
Old 31st October 2014, 11:59 AM
I tried a fairly strong magnet, no attraction to any of the exhaust, well not the tips or the back box. Sticks like glue to my rusty Ford Focus though...
Old 31st October 2014, 07:46 PM
Various grades of steel are used in exhaust systems. According to wiki, the steel grade generally used for exhaust sytems is:
"Type 409—cheapest type; used for automobile exhausts; ferritic (iron/chromium only)."
whilst "Type 439—ferritic grade, a higher grade version of 409 used for catalytic converter exhaust sections. Increased chromium for improved high temperature corrosion/oxidation resistance."
But as you may know there are 10's of differing grades of steel with differing properties and depending on the cost of a "stainless steel" system they could be using a number of types. Powerflow advertise that their exhaust "tips" are made from T-304. Double "S" uses three main types of stainless steel - Type 409 (Ferritic), Type 304 (Austenitic) and Type 316.
Old 1st November 2014, 07:15 AM
Oli18's Avatar
Oli18 Oli18 is offline
Hi I tried a couple of methods but below you'll find how I got the best results in this post 2 yrs ago...this is the method I'd recommend.
Oli
Hi,
With the recent refurbing of my wheels, i've been meaning to tackle the exhaust again. It was almost 3 years ago that i bought my S8 backbox from A8 Parts and although i got quite a good bit of traction when i cleaned it up, it still wasn't as good as i wanted it to be.
This weekend was the weekend to have another go and this time i used a few new toys...
Power drill
800 grit sandpaper on a wheel
Polishing mop with polishing soap bar (this stuff is amazing!)
Overall, quite pleased with the results and i've gotten the mirror finish that i've always wanted - although it did take about 2 1/2 hrs
Anyway, thought i'd share some of the results...
Oli
Before:
During (no pictures of polishing mop in use unfortunately):
After:
Audi A8/S8 D2 Flickr Group
Old 1st November 2014, 08:38 PM
That is brilliant Oli, very good results
Old 2nd November 2014, 10:56 AM
The exhaust seems to be full stainless the centre box is double skinned in a zintec or galvernised mild steel. The exhaust seem to be more damaged by heat the closer to the engine. Here is my 14 year old exhaust, the black paint of the rear box comes of very easy with cellulose thinners to reveal bright stainless.
Mmmm each bank has totally different path in the rear box ( very strange!) this may explain why each banks exhaust pipe has been affected by heat and corrosion differently.
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
Old 2nd November 2014, 10:59 AM
This is the centre box
2003 A4 avant TDi
1997 Volvo V40 2.0T
1976 Reliant Kitten
1965 Porsche 911
Old 2nd November 2014, 11:05 AM
This is the rear box after a 5min polish with the dremmel
2003 A4 avant TDi
1997 Volvo V40 2.0T
1976 Reliant Kitten
1965 Porsche 911
Old 2nd November 2014, 06:46 PM
Oli18's Avatar
yeah thanks - considering what it looked like when i bought it, I was pretty pleased!
Old 8th July 2015, 08:06 PM
Turbo Tony's Avatar
Oli, that's an AMAZING result!
Storytellers Villa Orlando
2008 Audi S8
