Old 18th January 2021, 01:58 PM
Stromaluski's Avatar
So a custom tool is in order The alloy piece on the left sits over the bushing which has the oil seal fitted to it off the engine. The tool then allows both the bushing and the seal to be pressed in to the front cover in one go, thus ensuring no damage to the seal
It fits together like this - tool on the bottom, bushing sitting in it, and the seal around the bushing
Fitting it to the engine. There is a precise relationship between the bushing and the seal. The tool is machined to just the right depth so that when the bushing bottoms out on the crank, the seal is pushed in to the correct depth.
Done. Very pleased with how this worked You can see how tight the outer lip is on the bushing.
Is that a tool that you bought somewhere or one that you made?
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
2010 Jetta TDI Cup Edition
Old 18th January 2021, 01:59 PM
Fascinating as ever and always on my 'watch list'.
Locked the cams in preparation for doing the chain tensioners. I forget - have I done a detailed write-up of how to do this job? I'm sure I have, but if not I'll make a separate thread if anyone cares to know the details - I took loads of pictures.
I know you've done the timelapse video of the job on the V6 and have posted several replies regarding certain aspects of the job. There are also a couple of PDFs with the instructions, but if you have the time, a full write-up of the procedure would be very much appreciated by myself and possibly others as you know all the little tricks.
If possible, could you also give a full list of parts and tools required (again, they're scattered around in other threads), things that might be required but not classed as tools (e.g. 'Assembly lube' below), as well as clarifying bank/side. As far as I know, the left side of the car is the passenger side (nearside) on a RHD car but the left side of the engine (I think bank 1) is the left side as you look at the engine from the front, and the reason for the clarification is if I remember from reading the PDFs previously is that the number of links differ between left and right bank.
Old 18th January 2021, 02:02 PM
It's bound to be homemade, just like the engine stand.
Old 18th January 2021, 02:21 PM
I made it yesterday The opposite end of it is the tool for fitting the gearbox rear ouput seal
Old 18th January 2021, 02:24 PM
Noted Bank 1 is right hand side of the car, cylinders 1-4. Tools are scattered around the workshop, as usual
I'll make another thread on this job once the car is back together
Write-up with pictures, narrated slide show, or real-time video?
Old 18th January 2021, 05:04 PM
Dimensions so I can see if I can have one made? Wonder if a 3D printed one would be strong enough...
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
Old 18th January 2021, 05:28 PM
MJ's stuff on these threads is like gold dust - even to someone like me who's never going to pick up a tool in anger . Imagine how much Audi would try to charge for this sort of product knowledge and level of detail ....
Old 18th January 2021, 05:59 PM
Ooh now you're asking! I made it the right size with the engine in front of me. I have no idea what size that actually is!
No way a 3D printed piece would be strong enough - the seal takes a lot of force to get in. Thwacking with a rubber mallet sort of force. Aluminium or brass is the way to go. I'll measure it for you
Old 18th January 2021, 06:51 PM
Is it the same as the "Thrust Piece" (Audi tool part T40007) featured in the Service Manual?
Old 18th January 2021, 07:17 PM
Interesting - that is designed to push the seal in without the bushing. Something I have not enjoyed. Mine is the opposite way round to that tool and pushes both in together.
